Question about Nikon Coolpix 5200 Digital Camera
How do i format my 1GB SD CARD FOR COOLPIX 5200 CAMERA
  • 3,153 Answers
Insert it into the camera
call up the menu on the camera for the settings
select prepare card (format)
Takes about 20-30 seconds for most 1-2 Gb cards
Posted on Sep 16, 2010
My Nikon coolpix 5200 will not let me re-set it. When I get the re-set on the screen it just skips past it. I just keep getting ( this card cannot be used ) on the screen & no memory card is inserted
If you can read the SD card with your computer, copy (backup) all images on the card to your computer. Make sure you saved ALL images. Then put the card back in the camera and FORMAT it. It is in the TOOL MENU that looks like a WRENCH.
Feb 25, 2017 | Nikon Coolpix 5200 Digital Camera
Nikon coolpix 5200 won't except 4gb SDHC card
Correct. The 5200 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 21, 2014 | Nikon Coolpix 5900 Digital Camera
My Nikon Coolpix 5200 is taking three photo,s not one, what do I do
Do you have the camera set on "BURST MODE" it sure sounds like it, if not you have a bad shutter button.
Jan 20, 2013 | Nikon Coolpix 5200 Digital Camera
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
I Purchased a new SDHC card from Argos which was 4 GB as the one that came with my Nikon coolpix 3700 is a 16mb I put this new one into my camera and the camera showed that you couldn't use this card,...
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Please take a moment to rate my free answer.
Oct 06, 2010 | Nikon Coolpix 3700 Coolpix 4200 Coolpix...
Do not know why my camera is saying that my card needs to be formated' I brought it into London Drugs camera department and they could not help me they say that I need to find the manual; a manual that I...
This camera only supports an SD card of 1GB maximum. I tried a 2GB SD card and the camera reported the error you describe, that the card needs to be formatted (and it wouldn't format in the camera, either). I purchased a 1GB Duracell SD card P/N DU-SD-1024-C at Wal-Mart, and it was actually a 2GB card (tested in my desktop PC's SD slot and it was fine). Nice deal, but this camera can't use it. I bought a 3-pack of Kodak 1GB SD cards at Wal-Mart and they worked great in this camera.
Dec 23, 2008 | VuPoint DC-M306AT-VP Digital Camera
Coolpix 5200 + 4GB SD card
Any size SD card will work. The capacity limit is with the card, not the camera. All the camera does is serve as a recorder/reader for the card.
Mar 04, 2008 | Nikon Coolpix 5200 Digital Camera
Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Nov 29, 2006 | Nikon Coolpix 5200 Digital Camera
Coolpix 5200 will not read sd card
Hope it's not the reader in the camera, first try rubbing the card contacts gently with an eraser and blowing in the slot. It may solve it, if not looks like an expensiver repair job.
Nov 27, 2006 | Nikon Coolpix 5200 Digital Camera
Nikon Coolpix 5200 Digital Camera Logo
93 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
