Question about Bosch Dishwashers
Water was cut off to dishwasher and it went through a cycle will this damage the pump or motor
  • Bosch Master
  • 43,501 Answers
No, they are made to be able to run without water and as long as everything worked as it should you will be okay...
turn the water on and give it a try, you will see that it is fine...
heatman101
Posted on Sep 16, 2010
Water does not flow through the drain
hello,
~Check for hose kinks or food plugging drain hose.
~Check pump impeller for damage
~Check pump motor for reversing during the pump out Make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
~Check timer for not letting the dishwasher pause.
~If you have recently installed a new garbage disposal, check knock-out plug at connection.
~Check the check valve and drain hose for debris.
~Check that the water inlet valve isn't seeping fresh water into the dishwasher when off. (if yes, replace the inlet valve).
thanks
May 21, 2011 | Home
Water is not draining after wash. What might be the cause?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit ( there are others, this is just an example )
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Apr 01, 2010 | Jenn-Air 24 in. DW861 Built-in Dishwasher
The dishwasher wont stop drying to drain . The darin is not blocked
check the following:---- Check for hose kinks or food plugging drain hose. Start at the drain port exit
  1. Check the check valve and drain hose for debris.
  2. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  3. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  4. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  5. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  6. Check pump impeller for damage.
  7. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    thanks.
Oct 10, 2009 | Dishwashers
Dishwasher not draining.
Hi
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Frigidaire Dishwashers
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Water does not drain
Hi
You can :
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
My dishwasher does not completely drain after a wash. what do i do?
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Nautilus dish washer won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
    ok.
Jan 06, 2009 | GE Nautilus 24" Built-in Dishwasher
The water in the water tank in the dishwasher won't drain
Dec 11, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
I have a whirlpool water softner. After regenerating, the water is still hard and the tank is about half full of water. I have cleaned the venturi.
Dec 06, 2008 | Whirlpool Dishwashers
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
