Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Dd6031 find it very difficult to close top drawer-seems something is blocking it-it has just happened
  • Fisher and P... Master
  • 3,247 Answers
The likely culprit is the drawer seal which is located at the inside top of the housing.
YOu will need to take the drawer out by pulling the plastic pins on each side to release the front cover. Turn off mains power to the unit.
Inspect the top inside to see if the seal is broken or rigid. It should move in if you press. If rigid then the actuator motors are misalinged or faulty. Needs service.
Hopefully if the seal is ok, then it is likely the drawer had come off the rail and was not going to the end. Put drawer back in making sure it is sitting with ease on the track. Replace front cover and test.
Posted on Sep 20, 2010
With 2 drawers, when you close the door tightly, it pushes open the top drawer, so the printer feeds from the incorrect drawer
take both drawers out and find the bit of rubbish blocking it up
a bit of paper or a clip or a staple is stuck in a seem ,,, or runner
Mar 05, 2015 | OKI B4600 Laser Printer
F & P Dishdrawer DD6031
The Problem is Related to the Dishdrawers Motherboard Control Center This usually happens when water condensation sits on the board to long and Short Circuits controls.
Jul 11, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
The top drawer of my dishwasher has just become extremely difficult to open or close, bottom drawer is fine. Can anyone suggest what the problem may be?
Sorry if this seems so simple, but try unplugging the dishwasher and plugging it back in. Ours had the same problem after our house cleaner ran it, it turned out that the cycle had been interrupted and the top-seal motor had not retracted the top-seal.
That worked for us, good luck w/yours.
Apr 17, 2008 | Dishwashers
Soap Dispenser drawer will not open.
Upon taking the top of washer off, it exposes the liquid dispenser. There are three snap clips on the right side as you look at it from the front. Unsnap and lift slightly on the dispenser lid. This should provide the clearance you need to open the drawer. Examine the blue covers for the fabric softener and bleach. You will see scrape marks where it has been rubbing on the the top cover when closing and opening. Using a soldering iron or an abrasive, wear down the sharp edges that are catching...This solved the problem for me.. ( :
Al Holm Chisago City, MN
Feb 22, 2008 | LG WM1814CW Front Load Washer
Hotpoint FFS70 freezer door won't close
there must be a basket that is bent ,
Jan 18, 2008 | Freezers
Drawers Stuck
the lid acuators have been up dated(due to this problem) though i find it hard to beleive both are bad
Jan 06, 2008 | Fisher and Paykel 23 in. DD603H SS...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
135 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
