Question about Bissell Vacuums
Carpet cleaner wont suction dirt blowing out instead
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 16, 2010
Dirt Devil upright has too much suction.
In a world where most people wish their cleaners had more suction, yours is a rare complaint indeed. Upright cleaners in particular are complaint-worthy as they soon tend to lose suction. It would be good to read more about the reason for your complaint?
Ideally an upright will have enough suction to lift the carpet from the floor a few mm and trap it against the mouth of the brush housing so air can be drawn through the carpet helping to lift out dirt so the brush can work more efficiently. An upright that is working correctly is much harder to push along and as they age they tend to be easier to push as they lose efficiency.
Most cleaners are fitted with at least one filter and they do rob them of suction. Some people remove the filters to improve the suction. Perhaps your cleaner has one or more filters missing.
May 06, 2017 | Dirt Devil Vacuums
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Bissell pro heat carpet cleaner blows out instead of sucking in
Is the full tank flapper (red) closing off the vacuum? Check the screen behind it to see if it's plugged up.
Aug 30, 2016 | Bissell Vacuums
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
Jul 10, 2014 | Dirt Devil Vacuums
Brought a dirt devil envision vacuum cleaner yesterday, assembled it and tried to use it. as i am running it, the dirt/dust seems to spread on the carpet/nothing seems to go in the dirt camister. The...
Fro what you say, the unit is blowing instead of sucking, There must be a pipe that is connected to the wrong outlet. Feel where there is suction instead of pressure, that is where your vacuum pipe must be connected.
Jan 30, 2011 | Dirt Devil Vacuums
Bissell Power wash /powerbrush sprays the carpet ok ,but when empty doesn't fill up with any dirty water from the carpet .Is there anything I am not doing correctly
It sounds like the suction isn't working right. Check the dirt tank to make sure it is on correct and check the red plastic filter on the dirt tank to make sure that it isn't clogged.
Dec 02, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
My carpet cleaner
There is a black ovule shaped gasket that sits between the top of the window nooze and the edge of the tank. If it is missing, then you lose suction at that point. Also is the filter on the end of the tank that sits over the square outlet clean?
Mar 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
