Question about Amcor Refrigerators
Hi, i moved an amcor meteor 590 fridge from one city to another. (it worked b4 it was unplugged.) now i put the plug back in and the lights turn on but the fridge doesn't work. it doesn't cool at all. what do i do? thanks
22yooper
  • 828 Answers
SOURCE: Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Posted on May 26, 2008
SOURCE: Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Feb 28, 2009
wheelshot
  • 102 Answers
SOURCE: Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Posted on Apr 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
co7196
  • 3433 Answers
SOURCE: Refrig constantly runs and is only semi cool, same w/the freezer. Left out in a cool room in the winter and stop running when it was cold. Started refrig back up and now runs constantly w/out cooling
Let freezer get down in temp and fridge should start chillg.Good luck
Posted on Jun 03, 2009
I am looking for a manual for an amcor fridge meteor 500 MF
Try this link
http://kitchen.manualsonline.com/manuals/mfg/amcor_inc/wv_50_1.html
I'm not finding a clean reference.
Please check the make and model numbers and then try to Google them yourself with the key words "user manual"
cheers
Jul 13, 2016 | Amcor Refrigerators
I have moved my bush fridge freezer bsbm166s and now the light is on but its not working
If you have laid it down when you moved it you need to have it in the upright position for 24 hrs. before plugging it in. (so unplug it. let it sit for 24 hrs. then plug it in.)
Sep 20, 2013 | Freezers
I need a restriction code for nokia 2220 slide
i need a restriction code for pink nokia 2220 slide its locked to meteor but need it to work an 02 sim card. imei:356239042591762
Oct 09, 2010 | Nokia Cell Phones
91 Honda accord none of brake lights working, fuse is good, bulbs are good
hi from uk if everthing you checked is ok ? then fault is probably the brake light switch is either faulty or the plunger that is supposed to move out as the pedal is pressed so putting b/lights on has stuck inside/off position? so if you look up at b/pedal just below the pivot shaft forpedal you will see the switch and it is srewed into the pedal box assy it has a plug of two wires connected ? pull off plug then use a wire paper clip opened up and join the two contacts in plug this makes connection to b/lights on have assistant check lights work when ignition is on? if yes? then remove clip ign off then unscrew the actual switch from its hole when removed? check if plunger is coming all way out or is stuck ? if either of these try wd40 on the plastic plunger and work it in/out when you are happy it works ok ? then b4 you refit just connect the plug and again test with ign on plunger out lights on! plunger in lights off if it works? then unplug and screw switch back in hole to approx last position and connect plug recheck b/lights operate as you press pedal approx 3/4 " b4 lights operate this is trial+error screwing in or out untill you are happy lights give early warning to following cars that you are braking ? however if lights work with clip but not on switch after completing above ? then you will need to renew switch they do sometimes melt contacts and burn inside mostly due to constant holding car with footbrake instead of park brake for long periods also a common reason for brake light bulbs blowing bad driving habit ! so consider this advise please and hope all is clear above ?
Dec 05, 2009 | 1991 Honda Accord
Not cooling fridge or freezer.
need cooling at the back, unplug for about 15 mins, move it for about 1 foot from the wall then plug back.
Sep 15, 2009 | Refrigerators
Haier hsp03wna not working
The click you heard is the thermal overload. This snaps open when the compressor is too hot.
Unplug the unit for 24 hours and don't move it.
Then plug it in and see if it comes back on temp.
Jun 02, 2009 | Haier HSP03WNA Compact Refrigerator
Subzero 590 shut off can't find reset button to turn back on fridge
There is no reset. There is an on/off but it doesn't trip. You should check the breakers at the breaker box and then call for service if the one for the refr isn't tripped
May 23, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge quit cooling after i moved it
did you tilt it when you moved it and then when u got it in place plug it in? if so youve got compressor problems, anytime you tilt a fridge you have to let it set for several hours to allow the oil to get back to the compressor or you ruin the compressor
Jan 01, 2009 | Refrigerators
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Refrigerators Logo
157 people viewed this question
Top Amcor Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Amcor Refrigerator Expert? Answer questions, earn points and help others
