Question about Samsung Televison & Video
HELP - Samsung DVD player P347
Yesterday, I tried to connect a projector up to my dvd player and was trying to get it to project the satellite television instead of the video. So I was on the Menu function of the DVD player and changed the setup - thinking that I was just experimenting - now the menu does not even show and I cant change it back to what it was so I can play a video! I can see its still working by the display on the DVD player but nothing shows up on my tv screen or projector. I have looked for a reset button on the dvd player but there doesnt seem to be one! Please help so I can just play videos again!
Michele
From the manual...
Connect the DVD to the TV via S-video or Video outputs (not component video) and...
• Press power on from a cold start with no disc in the unit. Press the
SEARCH/SKIP ( ) button on the front panel for 1 second.
The SELECT MENU LANGUAGE display will appear.
Select the number button of the desired language.
regards, Glenn
keraurus (at) gmail.com
Posted on May 24, 2008
No display from sony dvd player when connected to a projector
tried to hooked up your dvd player not in the projector, only in tv to ensure if it is working normally. if still the same problem might have a loose connection with in the dvd player.
Sep 02, 2012 | Televison & Video
I can't change the aspect ratio on my 1080 UB. It's locked in the "normal" view? How can I override this?
hi,
first of all check the video setting of ur DVD player or satellite receiver which ur connected to the projector. in its video setting select output video format aspect ratio as 16:9. the projecter will output the format what it get in its input.
u can elect the aspect ratio in the projector remote just press the ASPECT button to select different format
ok
Dec 31, 2010 | Epson PowerLite Home Cinema 1080 UB LCD...
Dell 1200MP works with PC but not the DVD player,
Hi.
If you have a replacement cable test the DVD using a different cable, you never know.
Try the following:
  • Unplug both projector and DVD from power.
  • Keep units connected together by video cable.
  • Connect back and restart the DVD first.
  • Restart the projector only once that DVD is ON.
If it still does not work , then there may be a fault.
Nov 09, 2009 | Dell 1200MP DLP Projector
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
DVD connection
You can use any dvd player to connect to this unit as long as it has either a S-Video plug or uses RCA plugs. These cables only transmit the Picture and not the sound. You will need to connect the DVD player up to something that can produce the sound as the HP only has a mono speaker.
May 21, 2009 | HP MP3220 Multimedia Projector
I am trying to connect my VCR/DVD player to my Sanyo need help
The VCR/DVD was not operating correctly. We switched machines and it worked fine.
Thanks
Dec 10, 2008 | Sanyo PLC XU35 Multimedia Projector
Fuzzy connection on my samsung DLP HLN567W
Try the DVD player on another component connection on the TV. If the picture is still distorted try another DVD player or something with component output. If thre picture is normal with another input device then the issue is the DVD player,
Nov 28, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Video input not recognized
Will it work if you change the input to manual and select the correct imput source?
Mar 18, 2008 | Hitachi CP-X275 Multimedia Projector
Connecting DVD VR357
direct to tv always best picture ok hdmi then sound from tvs digital outputs to input on your digital reciver ok
Jan 18, 2008 | Samsung DVD-VR357
Televison & Video Logo
Henry  Thomas
Henry Thomas
