Question about Dryers
Creda TCR14 runs for 10 minutes and stops - will only go if hold button in !! Leave for half hour and it will go again - seem oviously like thermal cut out problem, ut where it it situated ? Please
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 21, 2010
My lg phone wont turn on do you have a solution
You haven't mentioned which model of LG phone.
You could try removing the back of the phone and taking out the battery.
Consult your owner manual on how to remove the battery.
Press and hold the power button for 10 seconds.
Leave the battery out for half an hour.
Replace the battery and plug in the charger.
Leave it for five minutes and then try to turn it on again.
Apr 13, 2015 | LG Cell Phones
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 | Watches
Accutime batman watch time setting
if it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button.
push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
Apr 03, 2013 | Watches
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
I have set the run time on my salt water pump and then locked it back to pushing the buttons it shows the time but there are no green lights showing. Did I forget to do something?
one the run time is set you have 2 options
wiat 2-10 minutes for the system to lock itself and for the second green light to come on this mean you are generating
The other method is to lock it yourself do this by once your hours appear for run time then press and hold down arrow again till beep then press and hold up arrow till beep the hour will stop flashing and in 2-10 minutes your second green light will come on
Jun 12, 2010 | Intex Automatic Salt Water System for ...
The on off light keeps blinking, Help.
For my DCR902T - This is telling you that it is time to clean the coffee maker. Press the minute and hour buttons at the same time and hold untl the light stops flashing. Take out the water filter and fill the water tank to 10 cups and add 2 cups of white vinegar. Put the water tank back in, without the water filter. Take out the permenant coffee filter. Turn it on and leave it until about half the water goes through. Turn it off. Let it sit for about an hour, then finish the job. Then, run 2 pots of clean water through. You are good. It will notify you to clean your system every 40 pots or so.
Feb 20, 2010 | DeLonghi DCR902T Coffee Maker
How do I get a manual on a Creda Concept Solarglo Cooker
When i turn on the kitchens rings,they turn on for 10 seconds and after turn off for half minute and this process continue to repeate again and again. The indicates of screen change allte time, and i dont know whats happen with the kooker.Please inform me what to do. Thtank you!
Apr 21, 2009 | Creda C362E Electric Kitchen Range
Creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Creda Ovens
Dryers Logo
96 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
