Question about Canon imageRUNNER C3200 Copier
What is error code e000020-360 in irc3200 color copier
  • 153 Answers
SOURCE: Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Posted on Apr 01, 2009
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
  • 58 Answers
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Posted on Aug 07, 2009
SOURCE: error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Posted on Aug 21, 2009
Testimonial: "very helpful"
Douglessd
  • 284 Answers
SOURCE: Error code E000020-0000 in canon iR5000/6000
I found this solution. It seems to indicate a tonner problem.
http://www.copytechnet.com/forums/canon/7278-what-e000020-0000-a.html
Posted on Aug 26, 2009
Testimonial: "thanx...."
What is causing on my canon irc3200 error code E000020-0481
this code is for a bad OHP sensor, wich detects transprerencies.if you need canon support call now canon expert technician
Canon Printer Support
May 06, 2014 | Canon Office Equipment & Supplies
I have a yellow tint across most of the page on my canon imagerunner c3200 color copier/printer. I don't see it on the first pages but it tends to appear after maybe 20+ pages Maybe related to the...
Bottom line is that your yellow drum is failing. Back ground is very common on this model with older drums. It is not related to temperature. Your best answer is to replace drum. Always make sure machine is turned off durning any drum (imaging unit) change. If the high cost is something you don't want jump into then. Always run very short runs until error code E0000020 apprears. The irC3200 series is without a doubt is predicable. If your going to have an imaging issue it will for sure apprear between 10-20 copiers. If your colour changes to a muddy yellow or brown smear than it will be a cleaning blade failure. These two replaces are easy to do. Good Luck.
Jun 24, 2011 | Canon imageRUNNER C3200 Copier
Cant get the canon imagerunner c3220 to print from imac macosx -10
This is a tricky one. The newer MAC OSX does not like the older printer drivers. It usally requires extra software from Apple to deal with these products. Now that being said it should load by itself. I can tell you without a doubt you can not use the self installer as it will fail each and every time. To keep it simple get ip address of the iRC3220 and go in to you printer install and point it to the PPD file which you can get from the Canon website. Final point... There is a different PPD for iRC3200 with Fiery (C1 print controllers) and one without. They are not cross compatible. You will see iRC3200 with C1 and one just saying iRC3200. Pick the right one. Oops one more point the Queue name will be just the word print. Good Luck.
Jun 22, 2011 | Canon imageRUNNER C3220 Color Copier
Canon ir c3200error codes
There are many error codes which the iRC3200 has, please be more specific.
i.e. copy the exact error code displayed.
Sep 23, 2010 | Canon imageRUNNER C3200 Copier
Irc3200 will not boot up
A E0000-001 is a fuser error code.... You may be able to reset it. Press the "Additional Funcation" botton, then the numbers "2" & "8" at the same time, then press the "Additional Funt." botton. The display will change. To reset the code press Funcation, then CLR. then ERR , then press the "OK" on the display. Then turn the Main power "OFF" then back "ON". If this code shows up alot, you may have a power problem, if the code reset. If it will not clear you have a problem with the fixing unit. Good Luck...
May 26, 2009 | Canon imageRUNNER C3200 Copier
IRC3200 - Color Printing Distorted
hi
check your counter if already reach 2k
its means you need to replace the itb belt or assy
any question just leave a message
May 21, 2009 | Canon imageRUNNER C3200 Copier
Displacement colors irc3200
Usually thats the signal for a new drum. Is it any particular color that is out of whack?
Feb 17, 2009 | Canon imageRUNNER C3200 Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
CANON irc 3200 PERINTER
in the printer settings you can check there is a only one color selected so please change in auto coulor. if solve this ple letme konw at my email add ok sir take care
Mar 11, 2008 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Copier Logo
256 people viewed this question
old marine
old marine
