Question about KitchenAid KEBC107 Electric Single Oven
KitchenAid KEBS277WWH-O How does it self clean?
  • KitchenAid Master
  • 43,501 Answers
Hi, It self cleans by getting really hot and just incinerating everything including itself...
Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Sep 16, 2010
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
Can't unlock oven door
Put the oven in self clean mode, it will lock the oven, once the self clean mode has started turn the self clean mode off, give it a second and the oven should turn off. Same thing just happened to me and it worked.
Dec 24, 2010 | KitchenAid Ovens
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
Kitchenaid Superba Selectra 24
Before you decide to find out about the self cleaning feature... read this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Mar 14, 2010 | KitchenAid KEBC107 Electric Single Oven
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
KitchenAid KEBC107 Electric Single Oven Logo
140 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
