Question about Nokia 3110 Cellular Phone
NOKIA 3110 CLASSIC RESTART PROBLEM
I HAVE A NOKIA 3110 CLASSIC. WHEN I AM RICH IN 250 MB MEMORY WHEN MY MOBLIE PROBLEM IN RESTART SO PLS. SUGGEST ME WHAT I DO FOR THIS PROBLEM.
  • 11 more comments
  • kolin May 23, 2008
    NOKIA 3110 CLASSIC RESTART PROBLEM problem.plz help me
  • gurpreet2501 Jul 19, 2008
    Your phone has a virus in it ..This is the format code *#7780#
    After that it will ask password: 12345.Phone will restart .Then you r problem will be solved.If it is not solved by doing this.Then format your memory card...
    It will work 110%
  • ASDF009 Jul 20, 2008
    RESTARTING PROBLEM
  • dhawale Aug 05, 2008
    when i insert memory card my phone has restart auto maticly pls help me
  • Anonymous Aug 07, 2008
    why it restarting????/
  • avix Aug 09, 2008
    restart problem
  • Anonymous Sep 09, 2008
  • Anonymous Sep 10, 2008
    i just format the memory card but still
    my nokia 3110 c still restart
  • Anonymous Sep 17, 2008
    same
  • Anonymous Oct 25, 2008
    ihave also a problem of memory card.the phone is switch off when i insert the mmc
  • Anonymous Jan 25, 2009
    My Nokia 3110 Classic restarts each time I try to update my music play. It also restarts when I connect to the internet (I surf on the internet for ~10 minutes and it restarts). I have restored my factory settings and set a theme under 100kb, and it didn't restart while updating my music player. Well, at least I know how to fix the problem for a while.
  • Anonymous Feb 23, 2009
    when i turnon mobile it will restart again and again plz describe the solution
  • tikamgahlot May 11, 2010
    when i update my music library mobile automatically switch off.
Hi i am imran in kota (borkheda) my mobile Nokia 3110 c is 7 time problem in restart it is very serious and ptt problem. pleas help me. ok
Posted on Jul 15, 2008
  • fake id id is fake Mar 13, 2011
    1. Upgrade Phone software to 7.21 or latest (if available)....
    2. Ur phone memory must b free atleast 1 MB.
    3. Do not apply any heavy size themes.....
    Ur restart problem___SOLVED.
I have a nokia n72.when i swich on jst after few sec automatic cell restart
Posted on May 21, 2008
Im using nokia 3110c.
everytime i swtich it on it automatically gets turned off .. this happens 2 times then finally it gets turned off.. what to do?plz help
Posted on Dec 13, 2009
Hiiii
friends i also had the same problem but now my phone is working correctly. I just formatted the phone memory.For formatting the phone memory just go to the settings and then go to security change the access code the default code is 12345 or 01234 the
then press the formatting code that is *#7708# and clean up the phone memory it will not effect the phone book neither the contact will be deleted ..... please post your comments
Posted on Jul 21, 2008
First of all.. i would like to share my experience..and btw..im only 14 years of age. My nokia 3110 got these problems to.. the restart-ALOT thingy..so as i opend up this page i read them..then followed it..so it worked..heres what i did..:
1-turn off ur phone..
2-get the memory card thingy...
3-turn it all back on
4-if its already turnd on and u see its not restarting anymore..try to use it for a while.
5-if it restarts again..just let it be..
6-for a little while..put the memory card thingy back agaian...
7-hury! delete some files fast before it restarts again.
THERE! ur all done! if this works...GOOD FOR YOU!!
Posted on Nov 02, 2009
Hi
plz help me my nokia 3110 is restarting ?
Posted on Dec 26, 2009
My phone also having this problem.. when i turn on my handphone, it will automatically turn off ... what must i do?
Posted on Dec 12, 2009
    Problem Solver:
  • 5 Answers
FIRST OF ALL CONNECT YOUR MOBILE PHONE WITH COMPUTER THROUGH DATA CABLE AND THEN GO TO TOOLS ON COMPUTER SCREEN AND THEN SELECT FOLDER OPTIONS AND WHEN FOLDER OPTIONS ARE OPENED ,SELECT ,VIEW THEN SELECT {{{SHOW HIDDEN FILES }}} AND REMOVE THE OPTION FROM{{{ HIDE PROTECTED OPERATING SYSTEM FILES}}}.......WHEN YOU DO THIS A VIRUS FILE OF VERY SMALL SIZE IS SHOWED IN YOUR MEMORY CARD....THEN DELETE IT....AND REMOVE DATA CABLE INSTANTLY FROM YOUR COMPUTER AFTER DELETING FILE
Posted on Feb 26, 2009
  • JINDALHARSH Feb 26, 2009
    ALTERNATE SOLUTION............UPDATE YOUR MOBILE SOFTWARE TO LATEST VERSION
    IT IS UPDATED FOR JUST Rs.250 AT NOKIA CARE CENTRE
Type this code..*#7370#
Posted on Oct 21, 2008
The same problem
Posted on Oct 18, 2008
How can i increase the volume of nokia 3110c ???
Posted on Oct 17, 2008
This prob may appear through different forms like while updating library, using GPRS or playing game. it does so because the phone memory is being used by the application. i faced the same problem but not now coz i have found a solution. the simplest thing to resolve this issue is to keep your phone memory (not card memory) between 300k to 700k. it will definitely solve your problem. if you cannot manage to make it on standby mode to do so then remove your memory card and do the same. then insert your card.
good luck!
Posted on Sep 18, 2008
Friends.......the BEST thing i would suggest is that go and update ur phone software for free at any NOKIA CARE.......i am 1000% sure that it will solve all ur problems.
Please check the version of ur phone by pressing
*#0000#
compare the version with the version available at NOKIA CARE
if ur phone is in warranty they will do it free..
If u like my sugesstion just show ur courtesy by saying
thanks..........but only if ur problem gets solved
i think that the latest version available is V06.02...
thank u
Posted on Aug 16, 2008
I deepl liked the nokia 3110 but i wanna format it as i have a virus
Posted on Aug 15, 2008
Hi friends, me too have a Nokia 3110Classic
n had the same problem of restart
i just put out the card and Sim, then restored it, then again put it and used, believe me it made a complete one Month without any Problem. But after that its showing the same problem, i don't understand the reason, but now when i use this method again in condition of any problem, it reduces the time to being restarted rather than 6 to 10 time...
Try this and please inform me if i could help you in this regard.
at my E-Mail address
saqibateeq@gmail.com
Thanks
Posted on Jul 14, 2008
Wwww
Posted on May 22, 2008
These are not checked and guaranteed solutions!
#1
turn off your phone and remove mmc. then turn it on without mmc,and use it for about 1h. then turn it back off and put back mmc. now let it be turned off for a 10minutes. now turn it off and it will work properly.
#2
try to move some file from mmc to phone memory...some song or picture,etc,but you must do it fast,before it restarts...
#3
now,somebody said that nokia 3110c does support max 512mb mmc. now,if you have bigger mmc,try with smaller one's...
#4
somebody said that updating software will make your phone good.
try it if you want,but DONT DO THAT IF YOU HAVE WARANTY!!!!
Just to say,i have nokia 3110c and these solutions sometimes help :D ;)
Posted on May 18, 2009
Finaly I hawe hawe found the solution for restarting problem!
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.1. In SETTINGS/DISPLAY/ACTIVE STANDBY/ACTIVE STANDBY MODE (TURN ON)/PERSONALIZE VIEW (MAKE IT THAT SHORTCUT BAR IS THE ONLY ONE THERE)
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key,options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down,central button,left blue line,down,central,up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line,center,left blue line,down,center,center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
If this work at your phone just tell me because I would like to know did i helped :D
retardiran_boy@hotmail.com
Posted on May 24, 2008
Hello i am lopesh from india i aiso have the same problem when i insert memory card and when i update library it get restart so i have solve this problem 1. you have to remove your mmc
2. then you have to go in setting in that factory restored settings
3. you have to go in setting type code <12345>
4.your phone will get restart automatically
5.then you have to select a theme under 100kb
6. set it and wait for 10 minutes till you can you can change setting bluetooth set you set it to shown to all , then go profile my style in that you can personalise and increase volume and set
7.till that your mobile works properly for 10 minutes then you can switch off your mobile removed battery and then insert mmc
8.switch on your mobile it woks properly
9.and if your mobile get restart then wait for first restart
10.and fastly update music library the music player get update and your nokia 3110c works properly for4 to 5 months and if it get restarted ten you know what to do
till you not to do this
1. dont switch off phone and remove memory card
2. dont try to change theme
3. dont try to update library many times
you have to try all my friends those who read my solutions i always try these steps and my friends i am the only indian who live in mumbai city live in a small house in jogeshwari soooooo best of luck
Posted on May 25, 2008
3 Suggested Answers
SOURCE: NOKIA 3110 CLASSIC RESTART PROBLEM
salam
restore ur mobile factory settings
apply only builtin themes of nokia
do not fill ur mobile memory and always leave space of 500 kb
delete ur notes and celender notes
do not apply heavy wallpapers
hope the answer of question
Posted on Feb 16, 2009
Go to your Nokia Care center and ask them to upgrade your phone software.I do have the same problem and i did the same thing.
Posted on May 14, 2009
3110 Cellular Phone: i have nokia 3110 classic mobile.The phone does no...
it s due to software problem. u cant solve it manually. so pls contact your mobile dealer or service provider. before that try to do flashing
May 18, 2010 | Nokia 3110 Cellular Phone
I forgot my memory card password(MicroSD 512 mb Nokia 3110c)
i have nokia 3110 classic mobile. the memory card is nokia. i set password for my memcard. i had a software problem with my phone. so i gave for installing sw for my phn. after installing the software, when i opened my mem card it asked password. but i forgot the password. so i wnt to format it. but for formatting also it asks password. pl solve my problem
Jan 20, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
HELLO SIR......I WANT TO FORMET MY PHONE MEMORY(NOKIA 3110 )
Simple try to "Factory Restore"--> from option, before must u take backup at all.
---or try this---   By typing on it into your mobile:-  *#7780#
it just reset the phone.
Jul 20, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 classic Have the problem of restrart automatically?
its not a problem when insert a new memory card you need to restart the phone for it work fine. or this is what you should do, whenever you want to change memory card on your phone turn it off and insert the card the turn the phone on again. its a simplication. i think this solution will help you if apply it. thanks
Jul 02, 2009 | Nokia 3110 Cellular Phone
Security code nokia 3110 classic
pls tell me the security code or how to re format my cp
Feb 05, 2009 | Nokia 3110 Cellular Phone
salam
Sep 09, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 classic Restarting Problem
the firmware needs to be reflash or upgraded on the phone so you will need to take it into a mobile service center and have that done...or you can use you nokia software and upgrade the phone on your own.
Jun 23, 2008 | Nokia 3110 Cellular Phone
Nokia 3110
1 GB of memory is too big for your phone. you need to delete some files for your phone to operate normally. keeping alot of data in your phone will slow down your phone and i also keep restarting it. it it advisable to use 512MB of memory
May 23, 2008 | Nokia 3110 Cellular Phone
How can i hack my nokia 3110classic
on inserting micro sd of 512 mb my 3110 restarts..
if i update music library it restarts....
Dec 11, 2007 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
5,109 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
