I have a maxtor desktop basics desktop storage external hard drive, product number 9NZ2DG-500, i need to know what voltage the power supply for this is as i have lost mine and need a replacement, I have been unable to find the specifications online anywhere.
Hi
I have basics 500GB Prod No. 9NY2D4-592 and output is 12V hope this helpsI have a maxtor desktop - c60e870.jpg Gareth
Posted on Oct 01, 2010
I have a maxtor 500 gb basic desktop storage the usb pot on the hard drive went too deep into the case and its not waorking what should i do ?
I assume you mean an external drive. You will simply need to open the case (external drive case, NOT the actual HDD!) and re glue the USB port where it belongs. If the port had been soldered in place, you will likely need to re-heat the joints with a soldering iron.
Mar 25, 2011 | Maxtor Hard Drive
Hi I have maxtor 1TB external hard drive, not used it for over six month, now when I connect it, nothing happens, my laptop doesn't recognise or even sense/acknowledge it's existence!! Can you help?
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, at a significant discount.
Nov 04, 2010 | Western Digital My Book Essential Edition...
My maxtor external hardrive contains all our photos and suddenly my computer can't recognise it. help!
* USB cable
Nov 03, 2010 | Maxtor Hard Drive
Looking for power supply maxtor 3200
You can use any 12 volt power supply for these external drives from any electronics store but you need to make sure they are a 2 amp rating anything under that will burn out your power supply.
You will need to make sure the centre is the + if the supply comes with a selection of plugs.
Hope this helps
Jul 20, 2010 | Maxtor Basics Personal Storage 3200 Hard...
I have a Maxtor Personal Storage 3100 80 GB Hard Drive which has always worked and listed as drive G. However, on eday it just stopped listing drive G. Everytime I connect it to my port hub or to the...
Try a different "data" cable between your computer and the external disk-drive.
If there is an external power-supply, borrow a "multimeter", and test that the power-supply is supplying power (correct voltage and correct amperage).
Try connecting it to another computer.
Disassemble it, and disconnect the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk is working.
If it still is under warranty, either your local retail store, or Maxtor/Seagate will honour the warranty, and replace it.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Correct power supply for maxtor basics 500gb desktop drive
Look for the one that has the following DC output:
12Vdc 2A
Input in Australia is 220-240 Vac correct?
Mar 01, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
http://hddlist.com/maxtor/all/maxtor_basics_portable
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Computers & Internet Logo
212 people viewed this question
David Payne
David Payne
