Question about Kenmore HE2 Plus Front Load Washer
Our towels are not smelling fresh after they are washed and dried. Our washer is about 5 years old. Any suggestions?
  • Kenmore Master
  • 43,501 Answers
Here is a tip about how to clean your washer
Howto have a Clean Washer
heatman101
Posted on Sep 16, 2010
Washed clothes still smell dirty
If you don't leave the door open after each use you will get a musty smell and mold will build up in the bellows. also you need to wipe the bellows dry and the door glass dry as to not get a build up of soap residue on it which will eventually make the door leak. Also, only use one or two tablespoons of soap, not what the soap manufacturer says on the package.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I noticed that my clothes are not smelling fresh, especially my towels. The washer has a musty smell even after running it with bleach. When I shake the washer when it is empty I can hear water. Is this...
if it is a Maytag neptune YES that sound is normal. especially when you rotate the drum by hand that is your balance ring you are hearing. Do you only use liquid detergent? if yes this might be your problem. it leaves a film around the drum. i would run 3 wash cycles with bleach and hot water. and then at least once a month with hot water and bleach to keep it fresh and also leave the door open so that it can air dry oder causeing bacteria love moisture.
Oct 24, 2009 | Washing Machines
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Clothes smell musty
Clean th filter in the front of tha machine. Than take an OLD towel and run a hot wash with chlorox.
After that you run it again with vinegar and that should relief your problem.
i have an LG too.
Jun 21, 2008 | LG WM-2077C Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Kenmore HE2 Plus Front Load Washer Logo
41 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
