Question about Interex MultiSwitch 900
I would like to know the schematic diagram for light stairs that can be controlled on every floor, like for example if I have 6 floor.
  • 4,340 Answers
This wires like a 4 way switch, then you can install multiple extra switches of double wire, double throw (4 way) on multiple floors.
Posted on Nov 04, 2010
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
If floor to floor (height) is a 100" and stairs
no calculator on me but the answer is tan(100/134.5) because tangent = a/b and b is always the letter opposite of the angle
Jan 16, 2011 | Texas Instruments TI-84 Plus Calculator
I have a stairs with a switch and a bulb on each floor and i need to replace them with a wall pir sensor on each floor i need the wiring diagram
I answer questions for free.
I know electrical wiring.
I am unsure about a few things in your question.
Are you wanting to know how to wire a product you purchased?
Are looking for a wiring diagram to see if you can do what your want?
1) Is your circuit a 3-way circuit with 2 switches controlling both lights?
2) Or are there 2 different circuits where each switch controls one light?
Here is a Leviton manual with wiring for occupancy sensors:
http://waterheatertimer.org/pdf/Leviton-IPP0R-1LW.pdf
If you want sensors to replace 3-way switches, you need a control sensor and a remote sensor.
Click link below to see this image clearly
http://waterheatertimer.org/images/3-way-sensor-600.jpg
Add a comment and I will get back to you with specific details about wiring.
Oct 31, 2010 | Cooper Wiring Devices Motion Sensing...
I need to know what each color means on my distributor???
Review this guide as reference; this Electrical Schematic Diagram applies for 1994 Accord Coupe series of model. Here you will find complete explanation about electrical system of the vehicle. Started from Troubleshooting (tips and precautions) on handling the electrical system, in this manual you will be guided step by step examining each electrical component installed and its connection for example in Wire Harness and Ground Location, started from Engine Compartment, wiring harness is shown from engine ground cable, starter cable, and battery ground cable.
These 359 pages of pdf.fieltype manual is divided into some sections which are Wire Color Code, Relay and Control Unit Location, Wire Harness and Ground Location, Air Conditioning System Circuit, Anti-lock Brake System, Battery, Blower Control, Charging System, Cruise Control, Fan Control, Fuel Pump, Fuses, Ground Distribution, Heater Control, Ignition System Control, Lighting System, and etc.
Download the complete 1994 Accord Coupe Electrical Schematic Diagram here.
You can also find complete workshop manual of 1994 Accord Coupe here.
Pass: freepdfmanual.com
Good luck.
Sep 21, 2009 | 1997 Honda Accord
Kenmoore 70 series dryer wont start
Are you 100% certain the dryer has 240 VAC? Just because a light may light does not guarantee both legs of 240 VAC are hot.
If you measured motor continuity, then you must be able to read a wiring diagram/schematic. Most Kenmore units have a wiring diagram/schematic glued to the back of the rear service panel, or folded and stored in the control head.
I am unable to find a wiring diagram on the internet, but, you have a door switch, and the timer/control.
Use the wiring diagram to trace the signal path's to determine where the failure is.
Let me know if you have any questions and I will do my best to help.
Jan 21, 2009 | Dryers
1984 f 150 has electrical problems
if you know what your doing with auto wiring then yes its easy. you also have to understand schematics. if you can do that your golden. you can get a haynes book that has schematics at any auto part store, and you might be able to find them online
Jan 18, 2009 | 1984 Ford F 150
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele S251i Plus Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Green start light turns red and blinks 6 times. Is this a transformer problem? If so, do you know a part number and/or place to purchase the part?
The problem you have is with the G1 board. The 17 volts is not supplied. Do you have a multimeter and know how to trouble shott following a service manual schematic? if not call a pro to assist you as this could be the G1 board, but to be sure, you will need to troubleshoot and check some voltages and follow circuit flow using a schematic diagram. If you do know how to read, analize and follow schematics schematics contact me at techman32k@yahoo.com. If you do not, take the set to an authorized Sony repair center. Good Luck
Sep 18, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Interex MultiSwitch 900 Logo
100 people viewed this question
Top Interex Computers & Internet Experts
David Payne
David Payne
Are you an Interex Computer and Internet Expert? Answer questions, earn points and help others
