Question about Old Town Dirigo 106 Kayak
Large dent under the seat in dirigo hull -- bought this Kayak with the dent (actually a large bulge) in it. The dealer told me to set it in the sun and it should pop out. It has not i two days but the weather is not as hot a s it was in July and August. Can I use a heat gun to repair this area? Will the area stay in the correct form or will the bulge return? I can return this boat but it may be hard to find a replacement at this time of the year. I got a great price on the boat IF the problem can be fixed.
4 Suggested Answers
  • 17 Answers
SOURCE: dent in hull of kayak
umm....plastic or composite? If it's plastic, sit it out in the sun or carefully heat the dent with a heat gun and gently push it back out. Happens all the time.
If it's a composite or a rigid plastic kayak, you have a nice repair job ahead of you that won't fit into this space comfortably.
Posted on Aug 17, 2009
vpsoccer
  • 269 Answers
SOURCE: our sit on top kayak is about 7 years old . t6he
I do not know what you mean by a catamaran-style kayak.
I am assuming that it is a plastic kayak,. like most SOTs. Reshaping plastic boats can be difficult. If it was my boat I would try:
  1. If bottom flat, lay on flat floor like garage or deck. If not flat, then work on lawn.
  2. Let the sun (and maybe a bit of extra heat, but not much) warm the bottom so it is a bit pliable.
  3. Apply force to put the bottom back into shape. If not a flat bottom, then some extra care is required. This is usually done with internal blocks of wood or foam to hold the hull in its proper shape. In more extreme cases you can inflate an air bag in there to maintain pressure over a larger area. (BE VERY CAREFUL if you use an inner tube--it can burst your boat!)
  4. Once it is back to about the shape you want, leave it in that position for up to a few days, but at least long enough to cool down.
  5. With any luck, that will reverse most of the dents. If you don't get it all the first time, you might want to try again. In fact, I suppose it might be better to work on it twice rather than do too much in one go. I really am not sure on that part.
  6. With these poly boats, you may never get them back to original shape, but they will almost always accept some re-bending to get back to a more useable shape.
Posted on Feb 20, 2011
j2easy
  • 152 Answers
SOURCE: plastic piece on back of
I would say the best thing to do would remove the screws/bolts/hardware
plug the hole with whatever you took out. and buy a new seat with a higher back.
you may need to add those u shaped deck cleats but thats not a big deal
Posted on Oct 17, 2011
How can I repair?
Polypro kayaks are difficult to repair. Fiberglass are easier if you can reach into the hull. Polypro repairs are done by factory using a very hot melted material similar to hot glue gun material. It may time for this one to retire if it is 'bent' and as for the 'large puncture' well, that may not be fixable.
Oct 06, 2015 | Perception Kayaks Perception Essence 17.0...
The rack on the back crossbar is tilted so much that the kayak doesn't sit flat and actually is dented by the rack.
Move the rear bar toward the front one. As long as the minimum distance is there, and the kayak can be secured, you should be fine as long as your front and rear tie downs are secure.
Sep 01, 2013 | Malone Auto Racks Malone J-Pro2 Kayak Rack
I've had my 2013 Ride 115 for a month and half now. I took it out on a small calm lake and paddled for about 1 1/2 hours. When I went to put it on my trailer, I couldn't lift it because of all the water...
My first thought would be to check the drain plug which is located toward the back of your hull and quite possibly at or below the water line. Past that, there's a leak somewhere and you should take it to the dealer as it should still be under warranty.
Aug 12, 2013 | Wilderness Systems Ride 115 Kayak
Daughter is buying a Venus 10 via Craigslist. Has
Check the entire craft for brittle areas. It means that SUN-BAKING
has occurred. If the dent can be accessed from a port on the deck it is not a problem, but if it cannot, it may prove to be a weak spot. No WEAK SPOTS are allowed in a sit-on-top kayak. Get the longest craft you can transport/afford/lift always!
Aug 01, 2013 | Ocean Kayak Venus 10 Kayak
Will a dent on the bottom of a Venus to effect the boat's ability to track a straight line?
Oilcanning is a fairly common problem usually caused by improper storage or transport of your kayak, especially if it's hot out. Gently heating your hull (either by laying your kayak upside down in the sun on a warm/hot day or by using a heat gun CAREFULLY) MIGHT pop the dent out. If you were dealing with a single-hulled kayak, a little gentle pressure on the area with the dent while it's warm/hot would definitely do the trick. Not sure how I would approach a double hulled kayak, but it would probably be a combination of heat and pressurizing the inside of the hull or heat and water on the inside of the hull...would have to experiment.
Sevylor st5656 what air presure should be in it
The ST5656 is a low pressure hull, so shouldn't be inflated to more than 1 psi, or about as firm as a ripe grapefruit. If you leave it out in the sun you need to let some air out or the air inside will expand and it will blow up
Apr 04, 2013 | Stearns SEVYLOR Sit on Top Kayak U250
Plastic piece on back of seat busted looking where to find replacement its for a dirigo 120
Jul 07, 2011 | Old Town Dirigo 120 Angler Kayak
Our sit on top kayak is about 7 years old . t6he seat area has bulged up and underneath it has also bulged out . it is a catatmaran style kayak.
Aug 12, 2009 | Boating
Dent in hull of kayak
Jul 12, 2009 | Ocean Boating
Which kayak to buy
Plastic and fiberglass are the two materials the majority of kayak manufacturers are using today. Plastic kayaks are lower priced, have the largest selection of models and are known for being tough. The down side of a plastic hull is that it doesn't hold an exact shape, it's softer (therefore slower). It's close to weighing the same as fiberglass but you can't perform field repairs on it. Fiberglass is approximately $1000 dollars more for the equivalent-length plastic boat, but the hull is much stiffer, faster through the water and you can repair it. The down side to fiberglass is that it's more expensive, and if you drop it off the top of your car, you can crack it
Dec 01, 2008 | Wilderness Systems Pungo 140 Kayak
Old Town Dirigo 106 Kayak Logo
165 people viewed this question
Top Old Town Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you an Old Town Boating Expert? Answer questions, earn points and help others
