Question about Seagate 120GB 3.5" External USB 120 GB Hard Drive
The green light stays on the hdd until the cpu recognize the drive then it goes out and never boots the drive, but will contine to sound like its spining, also tryed on another computer and same thing could this be a power prob or the hdd itself
  • alabamalady3 May 19, 2009
    mine is having the same problem and i have not been able to figure it out yet any suggestions????
  • alabamalady3 May 26, 2009
    If i format it wont it delete my info on it????
    Genius:
  • 2,785 Answers
Have you formatted the hdd (check through disc managment tool)
Posted on May 17, 2008
Hard drive replaced. But does not recognize hard drive. Old hard drive but back But does not recognize hard drive.
open the CPU and check whether it properly connected (both the wires sata cable and power cable)
then check in BIOS. is it detected if it is then change the boot device priority..
if its not detected then try to swap the wires with optical drive..
still not then change the HDD
Mar 28, 2011 | HP m7170n PC Desktop
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
I have a HIPRO HP-305 power supply. The green
the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
P5NT won't boot
I went throught this and it is really silly. The P5N-T motherboard has a problem with some of the new energy efficient CPUs. The fix was to insert an older CPU and upgrade the bios and then it would recognize the new CPU. If you happen not to have an older 775 CPU laying around (most people do not), it might be easiest to return it and get a different board - or maybe the store can upgrade the bios for you.
Oct 05, 2008 | Computers & Internet
Seagate 120GB 3.5" External USB 120 GB Hard Drive Logo
121 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
