Question about Panasonic DMR-EZ48VK DVD Recorder
Panasonic dvd-video dmr-ez48v seems to be stuck in self test loop - error code u61 keeps coming up - will not switch on
SOURCE: Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
SOURCE: u61 on panasonic dmr es15
I have seen several postings regarding errors for the DMR ES15 recorder. I have resolved errors on my 15 month old device by cleaning the black spool that retains and spins the disc. Using denatured alcohol on a lint free cloth, I carefully cleaned the hub but did not saturate the material. This immediately cleared the no read and unable to record errors. Of course, I had to remove the outside covers to access the inter-workings of the read-writer.
Posted on Aug 10, 2008
shinma
  • 5 Answers
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Posted on Sep 21, 2008
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
  • 188 Answers
SOURCE: Panasonic DMR E65 cycling in self test on start up
Check the IC in the primairy power supply,common fault.
Posted on Jul 22, 2009
Panasonic dmr ez48v
We recommend you unplug all AV cables connected to the system and test a different electrical outlet. If the problem persists, we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 21, 2014 | Panasonic DMR-ES40VS DVD Recorder/VCR
U61 fault on an EZ28
Review the reference U61 in the user manual or maintenance, its posible that its needs format special or type of dvd-ram,
This failure apparently is very common in this brand Panasonic.
you will think twice when You will go to buy Panasonic.
Jun 22, 2012 | Panasonic Televison & Video
I get a U56 error message when selection drives? When I scroll down from DVD to SD then VHS. When on SD scrolling to down to choose VHS drive, U56 appears on DMR-EZ48V's screen? I have to select or scroll...
I ran into this on a Panasonic DMR-EA38V, and have discovered that yes, it is one of the input selected with the input select button. It will select DVD, usb, SD (for SD card), and VHS. Scared me for a minute!
Jun 27, 2010 | Panasonic DMR-EZ48VK DVD Recorder
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47VEB stuck on self check
Check IC in primairy power supply
Aug 29, 2009 | Televison & Video
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Aug 17, 2009 | Panasonic DMRES15 DVD Recorder
My panasonic dvd recorder is showing error screen u61, but what ever i do it does not solve the problem, ''self check did not complete''
First is there a disk in the dvd drive? If so it must be removed. have you tried a factory reset? Press and hold the up and down channel buttons on the front of the unit until the unit displays BYE then after it shuts down unplug it from the AC outlet for about 30 seconds then try to turn it back on it should be back in the first time setup.
Jun 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-EZ48VK DVD Recorder Logo
180 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
