Question about Acer Aspire 5004WLMi Notebook
Acer laptop is not detecting harddisk
Hello sir. as i told my acer laptop is not able to detect harddisk while installing windows XP. it first boot n comes for selection of drive (C,D..) then when i press enter to install. then it says that cannot access hardisk. N i tried to change in BIOS setup as u told. but their is such an option in BIOS setup.. Plz plz plzzz guide me sir its so important for me.
  • 655 Answers
Kiran,
i thought you have SATA interface, in that case your XP will not be able to access your HDD. But now as you told there is no option for SATA means you don't have SATA interface in your motherboard and the problem might be in your HDD.
  1. So, check out your HDD connection from motherboard and try to install again if no luck then do the following step.
  2. If you have important data/files on your HDD make a backup copy. Then make try to delete all partition and make new partition, then proceed further installation OR if you have recovery disk try to use it to recover your system as factory setting.
Thanks
Iqbal
Posted on May 17, 2008
Hye..my acer aspire laptop very bad causes of virus infection and mess with all my files and folders. so, it think reformat is the best solution for me. But unlucky, when i restarted my Laptop and install...
Hello !
You have said that you have done installation and Harddisk are not recognised this is a indication of damaged Harddisk ie its registry is bad or its not working .
I recomend a new Harddisk then you will able to use your laptop
Before you change the harddisk you should check the IDE cables by swapping them coz sometimes they could be faulty, connect new cable to the harddisk then on it try installation again .
Good luck
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
IC POWER LAPTOP CN5560 Driver
Here is a link to download a driver for your Laptop.
Open this link:
www.yboyandrei.com/CN5560
For windows XP 32 Bit Edition, download direct:
http://www.cpuid.com/download/cpuz/cpuz_152.zip
Please rate me.
Sep 04, 2009 | AMD IC Power CN5560 Notebook
I Have a Acer Travelmate laptop It gave me a System dll32 windows file missing. I've treid installing this file through booting with a Xp dvd but windows don't see any hard disc drives. What can I do now?...
For that First check in bios your harddisk is detected or not.
Then boot computer with winxp bootable disk then follow the procedure and repair winxp.
Aug 16, 2009 | Computers & Internet
How to install XP in Acer Extensa 5630Z
just goto the BIOS and make hard Disk detect as IDE simply by changing the Detect Harddisk as value SATA to IDE then u can install XP
Jun 04, 2009 | Acer Aspire 5610-4648 Notebook
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Acer Aspire 5004WLMi Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
