Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
  • lmela7385 Sep 16, 2010
    Update,110 on each side of element, no 220 across
  • 455 Answers
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Posted on Sep 16, 2010
How to access and replace elements.
Check out this tip..
How to replace the Thermostat and Element for Electric Hot Water Heater
heatman101
Aug 30, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Elctrical wiring of the thermostat Rheem hot water system
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
heatman101
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water is not hot, doesn't last long. Thermostats turn elements on when turned up. Elements show 230 when on.
Lower element can be burned out and still read 230V across screws
1) We know thermostats are working because elements test 230V.
2) We know upper element is working because tank has some hot water.
If upper element is burned out, tank will have no hot water.
http://waterheatertimer.org/How-it-works.html
3) Here's how to test lower element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
4)Here's how to replace element
Rheem element is 4500Watt bolt-in type
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
5) Rheem manual says: Heaters furnished with standard 240 volt AC, single phase non-simultaneous wiring, and 4500 watt upper and lower heating elements.
http://waterheatertimer.org/pdf/Rheem-spec-sheet.pdf
geno_3245_94.jpgRheem 4500Watt element
Nov 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Installed new rheem 40 gal elec water heater. model ge40m06aag. no hot y already checked breaker and am getting. 240v to the wh
did you turn the power on BEFORE you filled it with water???
this is a pretty common mistake. you will need to check the upper element to make sure its working.
most water heaters have an upper and lower themostat. the upper thermostat is the one we need to check.
use your volt meter...
turn the power off, test with your volt meter to make sure! remove one wire from the element, not the thermostat, and check resistance on the element. if no resistance, you burned the element, and will need to replace it.
replace with same wattage, usually 4500watts. it will be written on the element.
also, I like to push the reset button on the thermostat to make sure it wasn't tripped.
Aug 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Top heating element was broke. Replaced got hot water for week. Now have to run hot water for 20 mins before it goes from warm to hot. Top heating element reads 240VAC bottom heating element reads...
look for a badly connected power line ont he bottom element, or any connection upstream of the power terminals. voltage readings usually drop to that range when you only have one side of the 220v circuit connected.
Jun 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Apr 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Not enough hot water
Makes you feel good to save some money right? Have a great day!
Apr 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
163 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
