Question about Garden
I need a sprocket ,gear and rod for a 125 pound precise fit poly spreader...where can I find this? The part number is 45-02115-062.
  • 101 Answers
SOURCE: Front sprocket
Hi ........... One tooth less will give you more top speed (if you can pull top revs) but will reduce accelleration. If you go for one tooth less you'll need to tighten the chain and/or remove a link. It's a trade off ............ decide what you want the bike to do.
Posted on Dec 24, 2008
SOURCE: is the sachs zx 125 rear sprocket same as ktm
sorry i dont but do you no the code or number for a set of sachs zx 125 fork seals ????? email me antfarmery@aol.com
Posted on Jul 21, 2010
  • 25 Answers
SOURCE: I need spreader setting to do 2.3 pounds per 1000
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
Posted on Feb 23, 2011
  • 25 Answers
SOURCE: What would be the setting to cover 4 pounds of
Unfortunately, because granular products come in many different particle s and densities, there is no way to determine a universal pounds per thousand spreader setting. The only solution would be to do a 50 foot by 20 foot test. The 50 by 20 rule will allow you to determine an appropriate pounds per thousand rate for any product in anyspreader, but there is some work that will need to be done. *Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (Inyour case 4 pounds) *Place the spreader setting on a low setting about 1/4 of the way open. * Apply the 4 pounds of material over a 50 x 20 ft. area (This is 1,000 sq. ft.). *If material is left over, you are underapplying, and will need to increase the setting accordingly; before applying to the remainder of the lawn *If you come up short, you are over applying and you will need to decrease the setting; before applying to the remainder of the lawn
Posted on Feb 24, 2011
  • 65 Answers
SOURCE: I have lost my instructions
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
Posted on May 17, 2011
Craigslist citys
Google Panasonic TV camera.
I would not trust Craigslist for anything.
Jul 23, 2014 | Precision Camera Precision Products 130...
How can I lower my bike?
Fit a shorter suspension, maybe? Is it possible to attach the front fork 1-2 inch lower? You could mount a smaller wheel at the back, but the whole gearbox will be "shorter". If so you can keep the original gear ratios by mounting a smaller rear sprocket. The ratios of wheel diameters and teeth numbers should be the same, especially for a 125. Ask a mechanic.
Jul 21, 2014 | 2000 Aprilia RS 125
Sprocket foot pounds
if you got a locking tab that you bend lugs up to stop nut moving then 30 to 40 lbs will do ! P...
Dec 25, 2013 | 2004 Honda CR 125 R
I have a model 33 John Deere manure spreader that has the beater gear box with worn gears that won't engage. I cannot get replacement gears due to age of unit. Is there a way to repair the gears by we
There is no way to repair a worn gear, this is due to the heat treating of the metal to toughen it against wear and tear of use, otherwise it wouldn't last but a few hours of operation, this precise heat treating of the steel can only be done with special equipment and requires special skills to pull off correctly, so no you will need to get new gears. I know from personnel experience that you can get parts for these old farm implements, call around and see what you can find out. I will say that worn gears are not the common reason for hard gear engagement, that would be worn shift dogs and synchro ring cones or worn gear shaft bearings.
Dec 13, 2011 | Garden
Precise fit 85 lb tow broadcast spreader Can't find repair parts for precise fit spreader
repair parts can be found on amazon, click here and take a look: Amazon com Precise spreader parts. I hope this was helpful. Cheers
Apr 18, 2011 | Garden
What would be the setting to cover 4 pounds of product per 1,000 square feet? Scotts Drop Spreader PF4 Precision Green.
Feb 20, 2011 | Scotts Company Garden
Spreader propeller doesnt turn when i push it
I would think it is either it is stripped or loose gears or the roll pin which holds the impeller to the rod is missing. those things happen on the industrial spreaders I use at work.
Sep 17, 2010 | Scotts Company Scotts& Accugreeen 2000...
Losing power in last gear
If all other gears are doing okay then I would check with your local dealers parts department and ask the number of teeth on the counter sprocket and on the rear sprocket on a stock dtr 250. The prior owner may have mounted a larger counter sprocket and / or a smaller rear sprocket on the bike. The drive ratio may be out of range such that the engine is trying to make for a really high top speed but just doesn't have the strength to do it.
Please rate this solution. Thanks.
Mar 18, 2009 | 2005 Yamaha DT 125 X
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
