Question about Dell Vostro 1000 Notebook
When I plug the AC adapter into my DELL VOSTROO 1000 laptop, it doesnot charge. the only message i get is ' plugged in, not charging'.
The problem is with your battery charger, all my office has the same laptop and many of us (including me) have encountered the same problem. when we borrow charger from any other employee or buy a new one the problem fixes.
Posted on May 17, 2011
    Guru:
  • 1,481 Answers
Replace the battery....of the laptop...
Posted on Sep 16, 2010
New battery not charging
the old power supply must not be putting out enough power to charge
Jan 31, 2013 | Dell Latitude E6410 Laptop Computer (Intel...
Hi. i have a dell vostro 1000 which would not charge its batt so i bought a new batt that had no charge then charged it and it worked once. but now will not charge nor will the batt charge light stay on....
Could be many things, not necessarily in this order, but the ac adapter has gone bad(highly suspect), the power converter/charge board has gone bad, the power plug receptacle has an intermittent break in it from years of use (might be able to re-solder that one back on the board ) - or the new battery is not as new as you thought. In any event, You should send it to an authorized repair center - looking at a $100 bill or more.
Oct 02, 2010 | Dell Vostro 1000 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Vostro 1000 wont charge also 2nd machine same model has a ic blown on mainboard where can i get a schematic diagram also is there a general known fault with the charging circuiton this model . Rgds
Schematics for Dells are generally unavailable.
The not charging is normally due to a failure on the charging circuit or damage to the power plug (If ac adapter will not run system or if you have to play with the power connection.)
Replacement motherboards start at about $75
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1000+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=dell+1000+motherboard&_osacat=0
Oct 06, 2009 | Dell Vostro 1000 Notebook
My dell Inspiron 1318 laptop's battery is not charging.
check power supply see if its putting out voltage to laptop
Mar 29, 2009 | Dell Latitude C640 Notebook
Dell Inspiron 1501 AC Adapter error message
The Dell 1501 ac adapter (possibly other Dell’s as well) has been known to be problematic because of its lack of a plug to jack secure fit. You will notice that the plug can all too easily be pulled from the jack, as opposed to other systems where the plug fits more securely onto the jack. The plug and jack combination is poorly designed so that over time, the plug will come unseated depending on how much movement the machine is subjected to. This will result in power error messages or outright power-up failure. So before assuming you have a faulty adapter, make sure that it is not just a loose plug that is causing the problem. If you look inside the jack, you will notice that there is a 3mm region of non-conductive material nearest the surface of the jack. Use a strip of standard electrical tape 3mm wide and long enough and wrap it around the base of the plug (you may need more than one layer of tape to get a good fit). I have used this method to secure my plug and it has served me well. If the tape comes undone over time, just simply replace it. A more “elegant” method would be to use an “O” ring of the appropriate size (about 6mm) around the base of the plug in lieu of the tape.
Jul 26, 2008 | Dell Inspiron 1501 Notebook
Dell Vostro 1000 Notebook Logo
131 people viewed this question
Alun Cox
