The power and everything is on but the screen is dead
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Posted on Sep 17, 2010
Dead, Daewoo 42
You want to call the customer support for the company that made your TV. They will tell you everything. Or you could go to bestbuy or something and see if they will help. And one more thing, don't put your phone number on here. People will start randmly calling you.
Jan 20, 2008 | Televison & Video
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
May 16, 2014 | MSI G41m-p26 Desktop Motherboard - Intel...
My acer desktop computer screen is black, the power says it is on but no pic, keeps cutting off, tried to back up and restore, cut off, says problem with windows and it shut off as well, HELP!
  • When the computer will not boot up, it sound like it is booting as the CPU fan is running and the lights are on. It also finds the CD ROM but it won't boot from a CD either.
  • Sometimes when you have a computer black screen on startup and the power switch light will be green and then turns to orange or amber. Everything is running.
  • Everything seems to be running but you can't see anything on the screen, not even a flashing cursor. Your black screen in Windows has occurred before the Windows logo screen:
  • 1- adapter or video card
  • 2-RAM
  • 3-and Black screen on startup with an amber flashing light
  • Not enough power getting to the motherboard.
  • A dead power supply.
  • A bent pin or shorted out USB port causing a problem.
Apr 09, 2013 | Acer AX1430-UD30P Desktop Computer With...
Hi, Was playing "Call to duty" as usual, was
your problem might be that the power supply coming in has gone dead and that may be the issue i do not know unless i had more detail
Jan 02, 2011 | Sony Playstation 3 (PS3) Console
Turn tv on no picture everything else works. turn it off & on a few times maybe more and it comes on and stays on. what could be the problem thanks mike L
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check for bad soldering on the CRT ports and around the flyback transformer.
This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT port.
May 28, 2010 | Proview PA-32JK1A 32 in. LCD Television
HP ZD8000 won't power on
have you tried this with the battery removed from the laptop?
Oct 02, 2009 | HP Pavilion zd8000 Notebook
Dead laptop
Video card probelm. First see if the video card is not loose. Check the Bios to see that that display is enabled.
Jun 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Is this a terminal problem
It could be that your son dropped the DS. The screens are probbably not dead, but a connection may have come loose. The screen connection cables, especially the LCD power ribbon, are sensitive. You can try disassembling the DS by following any of numerous disassembly toutorials (search Google!) and make sure everything looks normal, that is, all the ribbions are tight.
Jun 20, 2007 | Nintendo DS Console
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
