Question about Sharp AL 1631 Copier
AL 1631 Sharp digital copier is flashing the code H4. Was flashing H3 reset it now flashing H4
  • 2 more comments
  • Rey Garza Sep 18, 2010
    I've already tried that it worked but then it started to give me H4
    ( AL 1631 Sharp digital copier is flashing the code H4. Was flashing H3 reset it now flashing H4 )
  • Rey Garza Sep 21, 2010
    it read H3 When followed the procedure to reset it worked for a while then started showing H4
    reset it again H4 comesback on
  • Rey Garza Sep 22, 2010
    Followed this procedure to reset; Pressed "clear", "exposue mode", "clear", "exposure mode" these 4 keys within 4 seconds, then entered 14, then pressed start, H4 Comes back on after reseting
  • Rey Garza Sep 29, 2010
    thanks
  • 1,110 Answers
H4 is an indication of a fusing unit heater problem. Most of the time this is a false code caused by power fluctuations or noise.
To reset the H4 condition, press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
Posted on Sep 22, 2010
    Guru:
  • 382 Answers
Follow this procedure to reset; once begun procedure must enter within four seconds; Press "clear", "exposue mode", "clear", "exposure mode" these 4 keys within 4 seconds, then enter 14, then press start, should take care the problem.
Posted on Sep 16, 2010
My copier is flashing the code H4
I have a tip posted here on Fixya that resolves this problem easily.
Here is the link:
http://www.fixya.com/support/r4376849-sharp_al_series_copier_h3_h_3_code_reset
If it works for you then please return here and provide feedback for me that I was helpful.
Thanks
Jul 25, 2010 | Sharp AL 1631 Copier
AL 1631 Grayscale Copier: letter h is blinking in the display unit does not ...
all the codes with(H4,H3,.......)can be removed by simulation 14
May 16, 2010 | Sharp AL 1631 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Oct 29, 2009 | Sharp AL 1631 Copier
Al1631 sharp copier
This is called error code which you must specify.For H2,H3,H4, use command 14, for U2 use comm 16.Please specify if neither of this displays.
Oct 02, 2009 | Sharp AL 1631 Copier
SHARP AL-1631 DIGITAL COPIER SHOWS ON THE SCREEN CODE H4 WHEN SWITCHED ON.
Hello sir; You do need following procedure to reset; once begun procedure must enter within four seconds; Press "clear", "exposue mode", "clear", "exposure mode" these 4 keys within 4 seconds, then enter 14, then press start, should take care the problem.
Jun 12, 2009 | Sharp AL 1631 Copier
H4 problems
Try to reset the error code by pressing : C exp1 C exp1 14 start. if the problem still occur then you should change the heater lamp
Apr 01, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 overheats after replacement of fuser and fans
Hello sir; that's a simple problem whayever you mention all the parts you replace are not necessary, if you can't reset H4,or H3 then you need to replace "THERMISTOR" that is the device to control the temperature, the parts #RDTCT0128FCZZ.
Feb 12, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
212 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
