Question about Epson CX8400 All-In-One InkJet Printer
Have an apple computer - epson cx8400 printer epson black 69 ink ran out my husband removed this cartridge before we had the new one to put in now printer continues to show press ok button to replace cartridge new cartridge is in but did black ink well dry up since it had nothing in place for a couple hours? answer and solution please.
  • 1 more comment
  • modmodel Sep 16, 2010
    to guru tried solution 1 No results (Note: I am novice - what is power button - OK button?)
    what else can I try? modmodel@comcast.net
    tried solution 1 did not work any thing else to try pls respond holding for answer
  • Epson Master
  • 4,737 Answers
First try this, remove all the cartridges, turn off the printer, unplug all the cables including the power cord, leave it for few minutes, clean whatever you think you can. Tap the power button several times. Reconnect and reinstall everything. Now try switching it on again. It should work fine. There's more to do if this doesn't fix. Let me know if the problem persists.
Good luck.
Thanks for using FixYa.
Posted on Sep 16, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 16, 2010
    Well, thanks for the patience, I got back just now, will respond within an hour, please give me few minutes so that I can make it clearer to you. Thanks
  • Lebanon Raingam
    I guess you've made a mistake, Power Button is the button labelled "On" and is the first on from the left nearest to you when you look from the front . Tapping the power button is very important, and you can't ignore it.
    I am not sure what you've done, but it's also very important to clean the contacts (golden metal dots) on the cartridges and on the printer (carriage) using a soft brush dipped in alcohol/acetone/spirit. After they are dried, reinstall them. Hope you did disconnect all the cables. Don't do it very fast, do it slowly so that the static signals may discharge.
    Let me know when you are done.
    Thanks
Epson stylus cx8400 will not print black, how do I fix
From the Epson web site:
Q:
Can the printer still print if an ink cartridge is expended or not installed? A: No. The printer will not operate if any cartridge is expended or removed. It's best to always have extra cartridges on hand.
I do this for fun not $$$.
Jim
Oct 16, 2011 | Epson Stylus CX8400 Series
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    Jun 10, 2011 | Epson Stylus NX400 InkJet Printer
    How do I remove the black ink cartridge to put in a new one?
    1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
    Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
    If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
    Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
    Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
    If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
    Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
    I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
    hello
    i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
    Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
    general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
    manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
    Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
    Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
    If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
    Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
    Epson stylus cx8400 cannot recognize ink cartridges
    I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
    Mar 05, 2009 | Epson Stylus R265 InkJet Photo Printer
    Printer cx8400 All in one inkjet does not print well (ink is new)
    have you tried to using the head cleaning? It will clean the nozzles inside your printer. you can check your manual how to do it.
    Feb 10, 2009 | Epson CX8400 All-In-One InkJet Printer
    Epson cx8400 Black Ink Cartridge doesn't work on Printing
    I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
    Dec 21, 2008 | Epson Stylus CX4800 All-In-One InkJet...
    Ink
    Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
    Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
    Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
    Epson CX8400 All-In-One InkJet Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
