Question about Whirlpool Washing Machines
My washing machine is unable to retain water.
  • Whirlpool Master
  • 43,501 Answers
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Sep 16, 2010
WASHING MACHINE NOT RETAINING WATER
Make sure that
A. the drain hose is above the hight of the water level.
B. there is an "air gap" between the drain hose and the stand pipe as the water can "syphon"out.
May 04, 2012 | Samsung Washing Machines
My whirlpool washing machine AWM 6085 is unable to **** in the water from the pipe during washing. What can I do?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 09, 2011 | Whirlpool Washing Machines
My whirlpool white magic washing machine 64408036-dlf is not retaining water
heatman101
Sep 16, 2010 | Whirlpool Washing Machines
I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
May 21, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Machine does not retain the water to enable washing to take place
The drain hose needs to come up higher than the water level in the machine, unless it is one that does not have a pump.
Apr 17, 2010 | Samsung SW62ASP Top Load Washer
My washing machine wont spin anymore
my washing machine makes a horrible noise while washing and retains water after spinning. what help can i get?
Nov 24, 2008 | Roper RAS6233KQ Top Load Washer
Simpson enduro 701 washing machine
After the water pumps out on each of the cycles the spin does not go or start and it gets stuck there.
Oct 28, 2008 | Washing Machines
Maytag MAV2755AWW Washing Machine is leaking water
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 11, 2008 | Maytag MAV2755A Top Load Washer
Water leaking from under the front of the washing machine
Dec 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
