Question about Kenmore Elite 45986 Front Load Washer
Pannel reads dl-f modle # 110 42926-203 - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
I got a SRU3004/27 philips universal remote control and i lost the code list
here is the manual of the remote... thought it was the codes, still searching for them. will post again if i found them
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/sru3004-manual.zip&area=other
Nov 27, 2009 | Watches
I 1983 Ford Truck Gauges all read low
Manualy Test These, and if they are Wrong the Cluster Curciut Pannel has too Much resistance to it , Probably Just From AGE Replace the Plastic Paper like Curciut Pannel Behind Instrument Cluster
Aug 05, 2009 | 1983 Ford Econoline
Need to change cabin filter. need diagram of location
dont belive the 03 modles have a cabin air filter there is a listing all the way to 06 but belive they stopped in 02. if it does remove black cover under passenger dash 3 7 mm bolts pannel pulls down and there will be a removalble cover under that in the heater box if its there
Jun 06, 2009 | 2003 Chevrolet Suburban 1500
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
In ir5000 i want to change my counter reading form 10000 to 15000
I'm not sure what you want to do? If you want to change you meter reading to a higher meter or do you want to make it lower? The meter is like the milage on a car. You really can not change it, you can disable the counter on the control pannel and then reset the counters in service mode. Or you can change the counter PCB on the rear of the copier withe another counter PCB. But you also have to change the reader and DC controller. It's not really worth it, it is a lot of work...... To disable the counter on the control pannel you have to take the control pannel OFF and take the pannel apart and clip the post that actuates the counter switch and put the pannel back togather and just say it dose not work never did. But you will only be able to sell it as a used copier. The count is stilled programed in the copier.
Jan 18, 2009 | Canon imageRUNNER 5000 Copier
Kenmore Elite 45986 Front Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
