Question about ASUS W5A Notebook
The inner power point has broken off & is attached to the power plug upon removal.
    New Friend:
  • 38 Answers
Repair shop job i say
Posted on Sep 16, 2010
How to repair drivers window
Remove door inner panel.. Look for why it fell .. It is off the lift track, probably something broke.. find broken part and replace or repair.. its not uncommon for window regulators to break.
May 31, 2014 | 2001 Pontiac Grand Am SE
Wiring diagrams
Check for power at glow plug, connect meter to earth and wire feed to plug, should get a 12v feed, if you get a feed the plug is duff. You can remove the plug and test for an Ohm's resistance, no resistance it's broken! If you have a power supply then it is possible the glow plug relay is not working. Follow the cable from the glow plugs, this is generally a thick 30/60 amp cable, the relay is larger than other relays and not in the fuse box, possibly on the bulkhead or inner wing because of the power it has to transfer. DO NOT DIRECT POWER FEED THE GLOW PLUGS, You can burn them out!
Dec 28, 2013 | Cars & Trucks
MANUALLY RAISE WINDOW 1990 LS400
remove the door panel the plastic clip attached to the window has broken away from the regulator arm. you can replace the regulator easily at that point or you can cut a 2x4 to fit and do not forget to unplug the regulator motor. jam the wood between the window and the bottom of the inner door frame.
May 26, 2012 | Lexus LS 400 Cars & Trucks
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My netbook is plugged in to the wall and the charge port but is not showing that its charging. why? and how do i fix it?
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | ASUS Eee PC 1000HE Netbook
Was using my Hp Pavilion dv7 laptop, suddenly turned off while the charger was plugged in. Turned back on then shut off again. Now my laptop wont even turn on, and there are no lights that even come on,...
Sep 26, 2010 | HP Pavilion dv7-1245dx Notebook
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
Hood will not open due to non cable release. any
It actually is going to depend upon where the break in the cable is. I'm basing this on the model year but you might check to see if any of the cable is still extended & broken off at the lever you use to open it. If you can see the broken strands you can easily clamp onto that with vice-grips, or similar pliers & pull on the exposed cable to open it. IF you cannot see the cable, you are limited as the whole intent of the cable system was to prevent anyone from opening the hood without the release cable. You can attempt to determine where it broke based upon the cable you pull out of it, cut the cable past that point without cutting the inner, "pull" cable, then pull on the exposed cable once out.
Next step would be to do some fishing out under the hood opening area to see if the small cable could be snagged & pulled but that's a slim chance.
Finally, Body shops are the best at getting to things like this since they usually have to dissasemble those parts for repairs, they would be best suited to remove other parts to gain access. good luck
Feb 05, 2010 | 2002 Toyota Sequoia
I need a left front door/window schematic on line for a 99 Dodge Durango. I need to see how to put it together.
Front Door
  1. Remove the door trim panel.
  2. Remove the water dam.
  3. Remove the inner and outer door belt weatherstrips.
  4. Lower the window to the full down position and align the glass regulator arm with the access holes in the inner door panel.
  5. Remove the front glass run channel.
  6. Remove the nuts attaching the glass channel to regulator arm.
  7. Separate the glass and lift it up and out.
  8. Disengage the power window motor wire connector from the door harness, if equipped.
  9. Loosen the bolts in slotted holes attaching regulator to door inner panel.
  10. Remove the bolts attaching window regulator to inner door panel.
  11. Remove the regulator through the access hole in the inner door panel.
  12. Installation is the reverse of removal. Tighten the nuts attaching the glass to the lift plate to 7 ft. lbs. (9 Nm).
Power window regulator mounting—Dakota, Durango
Window regulator removal—Dakota, Durango
Posting more on next post for door panel removal and installation.
Oct 26, 2009 | 1999 Dodge Durango
How to remove door panel on 1999 grand cheeroke, window is off regulator
Not that difficult of a task, it would be wise to get a service manual with step by step instructions and pictures. Factory ones are here for $20 bucks http://www.promanuals.net/dodgejeep.html
Trim
(1) Remove trim plug from mirror flag bezel.
(2) Remove screws attaching trim panel to door
(3) Using trim remover detach trim panel perimeter push-in fasteners from
door inner panel.
(4) Lift trim panel upward and separate from door.
(5) If equipped, disconnect harness connectors for
power accessories.
(6) Disconnect latch rods from inside handle actuator.
(7) Separate trim panel from vehicle.
Window Regulator
(1) Remove front door glass, (you may be able to access the regulator if the window is up)
(2) Loosen bolts attaching regulator to inner door
panel
(3) Remove bolt attaching regulator to inner door
panel
(4) Lift regulator upward to disengage bolts from
door inner panel.
(5) Disengage power window regulator harness
connector, if equipped.
(6) Remove regulator through access hole in door.
Jul 06, 2009 | 1999 Jeep Cherokee
ASUS W5A Notebook Logo
26 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
