Question about GE (PSS26MSRSS) Side by Side Refrigerator
Two things: One, when the fresh food part of the side by side fridge is on I hear a sort of clicking from the back near the floor. It's not so much a clicking as the sound of a small fan spinning not quite right. And there is a vibration sound. Also the bottom of the fridge leaks water. Not a lot but I have to keep a towel under it.
Mine GE makes the same noise. I have not water issues.
Posted on Sep 16, 2010
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
Whirlpool refrigerator model ED5FTGHKQ02
the closest model i could find was ED5FTGXKQ02 instead of ED5FTGHKQ02,could you check that and also what's not cooling both sides or just the fridge section,all it does is the evap coil gets cold in the freezer and the evap fan blows cold air from the freezer over to the fridge section,couple of the ings to check is open the freezer door,you should hear the fan blowing,if not you have a bad evap fan motor,if it is blowing from the bottom up remove the second bin or draw full of food and touch the back inside wall of freezer,if there's frost or like ice on the back panel you have a defrost problem,if everything is melting in both sides the compressor isn't running,could be a bad timer located in the fresh food section up front where the controls are or a bad start device located on the side of compressor,you might hear a clicking sound every couple of minutes.let me know what you find and check the model number,open the fridge door,look up on the right side wall near the ceiling or down near the bottom hinge on the door.thanks
Jul 07, 2012 | Whirlpool Refrigerators
WILL NOT COOL OR MAKE ICE. COMPRESSOR DOES NOT SEEM TO COME ON.
next time send the model number off of the fridge,side by side or bottom freezer model number is in fresh food section,right hand wall up near ceiling or on ceiling,top freezer look on left side wall.if the compressor isn't running most likely you have a bad start device located on the side of compressor,pull out the fridge,unplug it,remove the back outside bottom panel and you'll see the compressor,pop off the metal clip,remove the cover and slide off the start device or overload and relay same thing,then shake the device,if you hear pieces rattling around inside it it's bad,easiest way to check it,if you open the freezer door and you hear the fan blowing around most likely this will be your problem,you might hear the compressor clicking trying to start and it will be hot,also vac out the condenser coil and make sure the condenser fan motor is running good,over heating can take out the start device.good luck.
Jul 05, 2012 | Frigidaire Refrigerators
I have just purchased the above unit and has been plugged in now for 24hrs with no food, the high humidity warning sign Is illuminated constantly Is this correct?? Also I have yet to witness the operation...
You didn't include a manufacturer or model, so I can only offer general help with your problem. If you choose to provide this info later, you may get better, more specific help. The freezer compartment contains the cooling coil for the freezer and fresh food compartments. This fan in many fridges are not visible - but yours may be. Yours may also have circulation fans specifically for moving air around the fresh food compartment.
Generally, the coil is located in a protected area of the freezer (behind the back panel). The fan is arranged to pull air from the freezer floor through the coil to be cooled and blown out the top of the freezer compartment. Openings between the freezer and fresh food compartment allows a portion of the cold air to be blown into the fresh food compartment.
The first thing to do is to see what the temperatures are in both compartments. The fresh food should be about 36 degrees and freezer -10 to 0 degrees Fahrenheit. Place a glass thermometer (capable of displaying 32 degrees and up) in a glass filled with cold tap water, and place in the fresh food compartment. Place another thermometer in the freezer (capable of reading -10 and up). You can also use thermometers designed for fridge / freezer temperatures if you wish.
If there is nothing in the fridge and the door remains shut, the temperature should be seen in an hour or so. If the temperature range is obtainable, it is not likely that there is a humid condition INSIDE the fridge. You may have moisture collecting on the OUTSIDE of the fridge near doors, etc. If so, locate a humidity switch and turn it on. Many manufacturers provide this switch to turn on electric heaters in the outer part of the fridge cabinet where moisture tends to form in humid climates. These heaters operate to evaporate the moisture on the cabinet and usually come on when the freezer defrost circuit is on.
I hope this helps and good luck!
May 16, 2011 | Refrigerators
THE WHOLE THING HAS JUST STOPPED BEING COLD BOTH SIDES?
there is no motor in the fresh food side. since you hear a motor, you can eliminate your temperature control or defrost control. Check to see if fan near compressor is running, feel the compressor, is it vibrating, if not, do you hear any clicks or buzzing noises, if not, remove back wall of freezer and look for any frost or ice on the aluminum evaporator.
Apr 21, 2010 | Frigidaire FRS26H5AS Side by Side...
My freezer is working fine but by refrigerator is not working. how can that be with a maytag side by side?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Refrigerators
My kenmore fridge doesnt cool.
Possible defrost problem can you find the model number like 10651262103 for example on the bottom of the door frame near floor and behind the fresh food section door? I need to know that number to see what type of defrost system yours has. Sea Breeze
Jun 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing on whirlpool side by side fridge. Its a 2001 model... ED0GTQXKQ00
Inside the fresh food compartment near lights is the defrost timer. Turn it clockwise slowly until you hear refrigerator compressor start. If this works, replace the defrost timer. Let me know, Thanks, Sea Breeze
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator
You didn't mention it, but I'll bet there's a "humm" followed by a "click" noise coming from the back of the fridge. Even if you don't hear the noise, the starter on the compressor has failed. One of two things cause this... 1.) A mechanically failed starter. 2.) A seized compressor. If it's the starter only, you are in good shape. If it's #2 and the unit is less than 5 years old, it'll be a warranty claim. If the unit is less than 5 years old... do not attempt the repair yourself. Because, if you do and find the compressor locked up, you have voided your warranty and they will not repair for free. If it's over 5? Install a starter. We need the FULL model number off of your fridge to provide steps on this. It's located on a data tag affixed to the inner fresh food section lining. Most likely near the top on the right. Please post back with these numbers if you require further assistance.
Aug 11, 2007 | Kenmore 44109 / 44102 Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
