I require a manual for theSamsung SW655P Twin Tub washing machine
4 Suggested Answers
SOURCE: need instructions for replacing spinner motor
figured it out by oursleves - part came of old motor by twisting opposite direction to spin and pulling.
Posted on Apr 14, 2009
SOURCE: Spin dryer on my twin tub washing machine does
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Posted on Nov 07, 2010
  • 6277 Answers
SOURCE: GOOD DAY I would like to
I doubt that any washer will continue unless the drain motor is able to drain water. Many machines will not even go to spin or release the door lock if there is any water still left inside.
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 10, 2011
What causes the thin twin washing machine to shake violently?
out of balance is the main reason for shaking machines
out of balance can be poor distribution of the wash or the tub and machine is not level
Dec 20, 2016 | Washing Machines
Hi .have a tricity bendix 1000rpm.. seems to take ages to wash.. what is the timing on a 40 degree wash and a quick cycle
In the early days of Automatic washing machines, manufacturers endeavoured to get the machines to wash rinse and spin as quickly as washing could be done in a twin tub. However the results weren't always good. These days as they don't have to compete with the twin tubs the emphasis is on clothes care and energy saving. so the wash cycle is prolonged without a lot of bashing about and because wash temperatures are very low they need a bit longer in the tub action to achieve the results. Its the heating that costs the money not the tub action. nearly all machines will take up to an hour and a half or longer to wash properly. So you need to change your wash habits to accommodate a long wash time, don't try and do two or three loads in the same day, spread them out over a couple of days. If you are tempted to buy one of the Machines that purport to do washes in half an hour be aware this only applies to items that need freshening up and not normal everyday soiled clothes.
Aug 18, 2014 | Tricity Bendix Washing Machines
How do I fix water not staying in the wash tub of Twin tub, LG WP 750R?
If your drain is not high enough the water will siphon out while filling. Check your owner's manual for correct height, usually about 39 inches from ground
Jun 20, 2014 | LG Washing Machines
Twin tub washing machine
change the brushes on your motor
Jan 24, 2014 | Washing Machines
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Spinner on twin tub washing machine not spinning
I have had a manatee twin tub washing machine with spinner for two years. When I went to spin dry the first load this evening, it would turn on, but not spin. I read the above entry about another twin tub. I did the following... I unplugged the machine for 1 minute. Plugged it back in, then slowly and carefully turned the spin tub clockwise for 1/4 turn, then counter-clockwise for 1/4 turn. I cannot explain why it worked, but it did. So, try this trick before taking it apart. Good luck!
Jan 15, 2012 | Washing Machines
Spin dryer on my twin tub washing machine does not drain properly. There is water at the bottom of the tub
Thanks
Oct 06, 2010 | Samsung Washing Machines
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
ARE SPARES STILL AVAILABLE FOR TWIN TUB HOTPOINTMODEL NO 9404H NO61191982 IT APPEARS TO BE LEAKING UNDER THE AGITATOR NOT A HOSE PROBLEM
The part you require for your washer is still available.
It is called the wash spigot gearbox tripod bellows seal
If you have trouble getting hold of one, I can get one for you, if you want, they cost around £20.00 or so + p/p.
Jan 09, 2010 | Hotpoint Washing Machines
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
