Question about Sony KDF-E55A20 55 in. LCD Television
Tv not staying on
The tv goes off and on every couple of minutes. the fan is still running and we cleaned the tv. could you help me find the problem and give me the part number so i can replace it .
  • KDNADN Jun 15, 2008
    I also have the same problem. The TV stays on for a minute or so and then the picture and sound go out. After a while the picture and sound come back. The green power light is on while all this happens. This happens over and over again.
  • 3 Answers
I had the same problem with mine. I took the lamp out, comes out from the front, and cleaned the screens on the top and bottom of the lamp. If these are dirty, mine were, they are preventing the bulb from dissipating heat. This causes the tv to shut off the lamp to cool it down. Mine works like a champ now.
Posted on Aug 31, 2008
  • 3 Answers
If your pic and audio goes in and out evry 10 to 15 second or more then you need to replace the lamp.ITs not complicated to change the lamp.
Posted on Jun 24, 2008
Light goes on and off lightware vp800
Hi, How long have you had the unit? If its new take it back and get warranty repair. If longer then, try giving it a good clean. Get some "Air Cans" if you can to blow trough the vents. It could be dust/dirt on the sensor. If you clean it first then we can be sure. If you are ok about taking the casing off then you can give it a better clean. If after cleaning it is still playing up, it is an overheating problem and best repaired by proper service centre as they can get the parts you need.
Sep 08, 2007 | Audio Players & Recorders
Sony 42 inch plazma display on screen ...fan problem powering down
if the fans are stopping you will need to replace them
Apr 29, 2014 | Televison & Video
Compressor will not stay on no matter the temp. setting. After running a couple of minutes the unit emits a scraping or buzzing noise and compressor goes off.
Sounds like you lost one of your fans if air is circulating in the room its the condenser fan. Thats what blows across the condenser coil to the outside. It may just be a capacitor thats what helps the fan get started but usually if the fan is popping capacitors there is something wrong with the fan but at the same time capacitors do just go bad. hope this helps let me know.
Jul 23, 2011 | Frigidaire FAH126S2T Thru-Wall/Window Air...
I turn my car off and take the keys out but the fan keeps running?
if the car is warm the fans are designed to continue to run untill temp drops to normal temp and then fans shut off. This is a normal operation of the fan nothing to worry about. Now if they stay running for more than 10 minutes you have a problem.
Feb 03, 2011 | 2003 Mini Cooper
Projector keeps turning off
Replace the fan and all fuses on the circuit board,if it is LCD or 3LCD clean the LCD, check the wattages with a tester.
Jan 29, 2010 | Dell 1209S DLP Projector
It sounds like the fan is going out. Have replaced light bulb comes on and stays for a few minutes then goes out again
have you cleaned the air intake cooling filter.. if not do so. it is located either side low you will see a couple screws and the actual filter.. if the filter is ok then the power supply is getting ready to fail...best to get it checked out by a serviceman......
Nov 23, 2009 | Vivitek V37655 56" DLP TV
AFTER A FEW MINUTES OF OPERATION ON MY SONY KF-42WE610TH LCD PROJECTION TV THE SCREEN GOES BLACK.THE SOUND COTINUES AS NORMAL.AFTER A COUPLE MINUTES IT COMES BACK ON THEN REPEATS UNTIL THE SET HAS RUN FOR...
First blush - the protective device called a "thermister" is heating up and "fusing". When the system cools down, the thermister releases the protection and allows the highvoltage transformer to provide power again.
Often times a device is drawing too much current - and the thermister shuts off the device to protect it - much like a fuse.
I have been able to maintain service on my TV by adding more cooling air to the existing fan. If your cooling fan is not turning fast enough - it can also cause the problem.
Nov 14, 2009 | Sony XL-2100U Projector Lamp for...
Shutdown
Try cleaning the air filter and see if that solves the problem.
May 26, 2008 | Televison & Video
DLP tv
need the model number of your set in order to help, but it sounds like a problem with the light engines shutter
May 14, 2008 | Televison & Video
Sony KDF-E55A20 55 in. LCD Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
