I need datasheet for smsc mec5025 nu - Computers & Internet
What chip it is
The chip number you provided is for the IC chip itself and not the circuit board. It looks like the IC chip is made for laptops and computers, and as far as I can tell it is a logic board for an apple product. 12_29_2013_9_13_54_pm.png
Dec 27, 2013 | Computers & Internet
Power on is ok but when switch off not ok
They are lightly loaded and WILL take time to bleed off the charge on the caps.
Also switching power supplies MUST have a load on them or they MAY overvoltage.
Sep 07, 2009 | ASUS PSU | A-45GA 450W RT (A45GA) Power...
Smsc motherboard jumpers setting(compaq presario 5000
no need jumpers, the smsc are being setup in the BIOS, enable it or disabled... go to BIOS Setup
Jun 19, 2009 | HP Compaq Presario 6310US (DA201A#ABA) PC...
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Message problem
try restoring ur mobile to: Manufacturer's settings,
remove, the smsc no(of course, write it down in paper) in message -->settings., restart ur mobile.
(if deleting doesn't work, give a dummy no as smsc no. and select it as primary, delete the default one , and restart.)
it will mostly solve the prob. then restore the smsc no with origiunal no (which is already written on paper)and again restart ur mobile.!!!
if it didn't , ":-)"
Dec 06, 2008 | Nokia 6131 Cellular Phone
Sony ericson P1
probably your smsc number is not correct.
You can find it in 'messages' -> settings
Every provider has its own smsc number. You can aslo check the manual from your phone how to change it. And check your telecom provider website for the smsc number.
B.r.
Sep 01, 2008 | Sony Ericsson P1i
Motherboard not powering up
hi this is parveen
solutiom for d845gvsr not poweringup only led flashing--
short pin 92 and 93 of smsc LPC47M172 with fine tip soldering iron .
pin 92 is nrsmrst signal that is 3.3v at time of working m/b when this signal is low than motherboard not powering up so we short pin 93 that is standby (3.3v) and motherboard powering up again and working properly this problem doesn,t come again in future. this solution is 98% working 2% chances to change the chip.
Aug 07, 2008 | Intel Motherboard
No power-up only the little green light by the cpu lights up
I tried Parveens solution for this problem on 2 absolutely dead D845GVSR mother boards and it fixed the problem for me on both. On mine you had to permanantly short pins 92 & 93 of the LPC47M172 IC near the ddr ram slots.
There must be a reason for why the motherboard went dead in the first place because from the factory, pins 92 & 93 of this IC are not meant to be shorted. Albeit the motherboards work perfectly the shorting of pins on this IC get over the problem but the original fault is still really there but has been bypassed! Still having said that, what a result!
Feb 02, 2008 | Intel Motherboard
Computers & Internet Logo
333 people viewed this question
David Payne
David Payne
