Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I replaced the power supply board in my WD62525 that fixed the no picture problem. but the remote will not work after that. It is not a remote problem I have 2 remotes and they both will not work. I took the tv apart thinking I may have left some thng disconnected everthing OK no bent pins are anything. Could it be the power supply board that I replaced.
  • sa49 Sep 21, 2010
    If you read my question I ask would the power for the remote reciever board come from the power supply board I replaced. The board I replaced is part# 930B9210 MAIN POWER SUPPLY BOARD. The remote worked with the old power supply board. and I have checked all conections and even have unpluged all conectors and looked for push backed or bent pins., every thing is OK. The remote has new batteries lights up and should be working I also have an other remote and it will not work the TV . You can not even turn on or off the TV.
  • Mitsubishi Master
  • 19,396 Answers
Hi.
Find the board where the IR sensor (the sensor receiving remote) is located and check board connectors.
Board should be 935D776001 control board, but check also 935D779001 front pwb. Below the service manual.
Before doing anything else ensure that problem is not a faulty remote. Eventually do a factory reset as described at page 25 of service manual.
Here service manual.
Posted on Sep 16, 2010
  • Ginko
    Ginko Sep 21, 2010
    The main PSU supplies power to any other board comprised in the TV, including the IR sensor hosted in control PCB or in front PCB.
    If the board hosting IR sensor is not powered, then track continuity to PSU. If the board is powered, then replace the board with IR control.
  • Ginko
    Ginko Sep 21, 2010
    The sensor should be in the control board assembly, the one behind the cover in picture:
    The PWB control (control board) is connected to preamp board and to terminal board to go finally to DM board, all board are powered by PSU.
Im having a problem with our Sony Bravia T.V. When we turn it on the light goes green but the tv stays black, no sound either. Cant turn it off with remote or on TV. The only way is by unplugging it.
Most likely the power supply board needs to be replaced. The fact that both the sound and picture don't work really points to that board.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Nov 14, 2016 | Sony Televison & Video
Fix philips tv
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 05, 2016 | Philips Televison & Video
How to repair a flat screen tv that has no picture
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
It will be best to contact the authorized service center for Philips.
Aug 01, 2014 | Magnavox Philips LCD TV Remote Control...
Hi, When I turn on the TV using remote control and also using power button on TV, red LED just blinks. No picture on TV screen. Pl. suggest as what is wrong and how to fix this problem.
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 13, 2011 | Panasonic TH-42PX60U Television
When I select view tv activity on my Harmony One, my Samsung tv clicks 15 times before it turns on displays a picture.
It not the remote.The tv have problems,with it power supply board,it have a problems,it not giving ur tv the right voltages anymore,that why it take a long time,the tv to turn on.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 14, 2010 | Logitech Harmony One Advanced Universal...
Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture (black screen) after remote control button-presses
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 11, 2017 | Samsung Televison & Video
Tv switches itself on and off no picture
Just had this happen to me. It's caused by a failure of the power supply board. Replacing the power supply should fix this issue.
This appears to be a very comon problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy.
Mar 25, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
No picture
Open the back cover and disconnect the Y - Board Vs plug from the Power Supply board. Check the Vs voltage in Power Supply board when turn on the tv. If the Vs voltage is there, it means the power supply is good and try to replace the Y-Board. Otherwise, try to replace the Power Supply board. If your tv is still in warranty, just let the warranty depot shop fix tv for you.
Jan 27, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
