Question about Mercedes-Benz Vehicle Parts & Accessories
1996 c220 dead battery for 6 months, battery dead on key romote also. batteries both replaced. Radio in car is after market. Motor will fire with starter fluid. % gallons of gas added to tank. No blinking lite on dash. What should I do to get the car to run.
  • 2 more comments
  • mk7354 Sep 16, 2010
    As I said it runs while spraying starter fluid, stops running when starter fluid stops. Where is fuel pump fuse and relay? Where is fuel pump ,in tank or? I believe fuel pump is not working. Could this be caused from security system being without voltage for so long? Is there
    a code to be intered? Max
    Motor runs on starter fluid Problem seems to be not getting fuel. Is this a security program problem? Where is fuse or relay for fuel pump? couldn't find in two fuse boxes. Where is fuel pump,fuel tank or? No lite on dash for security like small blinking sometimes found on some autos. Max
    How do I make the fuel pump work?
  • Raymond Russell Apr 10, 2013
    I have a 1996 c220. I tried locking my trunk on it the other day with my key (turning it to the right) and when I did the car would not start. I then unlocked the trunk with the key, turning it to the left twice, and my car started. You could try that to see if it will start then. I'm not sure if that is some security feature or what but thats what happened to me. Hope it works for you.
  • 944 Answers
Does the car crank when you try to it turn it On.
Check the fuel pump.
Check the fuel pressure.
Check the spark plug and clean it.
If it Does not crank then you have to check the ignition system is the problem.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 16, 2010
  • 4 more comments
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 16, 2010
    It is under the car around where the battery but under you have to lift the car up.
    next to the fuel filter it is covered with a plastic cover with 3 screws.
    remove this cover and you will see the pump and the filter . Next to the battey is fuse is located.
    remove this cover and you will see the pump and the filter . Next to the battery is fuse is located.
    How do I get power to fuel Pump?
    Check the ECM, it gives power to the fuel Pump.It controls the fuel pump.ECM board will be located near the engine.
    It supplies the fuel from the tank based on the pressure.It can be only replaced.
Mazda 6 - Wont start, just clicking noise when key is turned. Battery seems dead, but radio etc came on??
radio don't use as much voltages (AMPS) as the starter motor. remove battery and charge up. remember radio is coded so you will need to put the code in after. negative lead first off the battery.also have ignition turned to number 2 then turn off and you have 30 seconds to remove the battery. if not battery starter motor solenoid has failed and a new motor is needed. check battery first.
Oct 11, 2013 | 2006 Mazda 6
I have a 1996 Mercedes C220 and I replaced batteries on the remote because they were dead. Well at least I hope it was that and the remote isn't messed up. It's the key that flips out. I wanted to...
They are mated, there is no need to reprogram them. I assume that the key starts the car and the problem you are having is that the remote does not lock and unlock the doors. If you have a second key and it works properly then your first key/remote is broken or you have the new batteries in wrong. If you push and hold one of the buttons there should be a light that flashes on the remote. (some do not have this). A replacement remote has to be ordered at the dealer and will either come pre-programmed for your car, or they will do it when the key shows up. Nothing the home user can do here really.
Aug 31, 2011 | 1996 Mercedes-Benz C-Class
1996 mercades c220. Been setting for 1 year. I put in new battery in auto 2 new batteries in key remote. Motor will run with a shot of starting fluid. No fuel to motor. Fuel in tank. Is this a security...
There is a fuel pump relay under the hood on the drivers side. I don't think it is a security problem. Security shuts down the ignition. So it is probably the fuel pump. And the fuel pump is inside the fuel tank.
Sep 16, 2010 | Mercedes-Benz C-Class Cars & Trucks
How do I jump start my 1996 C220 Mercedes
Hook positives to positives on each battery, then hook negative to your battery and other negative to frame of other car.
May 10, 2010 | 1996 Mercedes-Benz C-Class
MY ISUZO START REALLY SLOW LIKE IF THE BATTERRY BE DEAD AND THEN
SOUND LIKE WEAK BATTERY. CHECK BATTERY VOLTAGE.IT SHOULD BE 12.5 VOLTS.IF NOT CHARGE BATTERY OR REPLACE IT. IF BATTERY GOOD.YOUR BATTERY CABLES IS CORRODED OR WORN OUT.OR THE STARTER MOTOR IS BAD.REMINDER DUE TO LOCK OUT FEATURES.BESURE TO TURN OFF RADIO BEFORE REMOVING BATTERY CABLES.OR YOU WILL LOSE CODE TO PLAY RADIO.
Sep 25, 2009 | 1996 Isuzu Hombre
HOW DO YOU CHANGE THE BATTERY ON THE REMOTE KEY FOR MY 2008 BMW 328I
Hi , unless you car has been fitted with keyless entry you can not replace the batteries on the romote key , it sounds like the only sollution is to reolace the romote , regards mark
Aug 10, 2009 | BMW 328 Cars & Trucks
Dead battery mercedes 03 e320
hi, if you jack up the car at the front you can power up enough voltage via jump leads red to starter motor and black to earth, hope this helps you, cheers
Mar 06, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Vehicle Parts & Accessories Logo
129 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
