Computers & Internet Logo
Posted on Sep 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NOT THE SOLUTION .... in our coll there are about 50 hp monitors and out of which 25-35 have the same menu problem .. the blue menu box comes and goes away automatically or it never goes (it's very irritating, specially when we write programs or watch output's) .. ANY ONE WORKING IN HP PLEASE HELP THIS MALFUNCTIONING ..... If any 1 found the solution please mail it to [email protected]
Anonymous
Level 3:
  • Master 732 Answers
  • Posted on Sep 16, 2010
Anonymous
Master
Level 3:
Answers
732
Questions
Helped
297718
Points
2071
Faiz ahmed32, If that many units have failed, then you should open at least 3 of them and check the power supply boards for "failed electrolytic filter capacitors" that may be causing this common symptom!! Try www.badcaps.net , http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Please report back your findings if bad capacitors is the cause of monitor problem. Also report the brand name of the capacitor manufacture here so everyone else will know too!!! 12fixlouie
Menu box on screen won't come off
If the buttons are micro-switch type buttons (like you would have on a car's alarm remote) and they don't have the proper feel, then the monitor is probably ready for the recycle bin. Doing a little looking around it appears that the monitor you have is prone to failure. I think you should look into a replacement. Samsung makes a great monitor these days. I would steer clear of anything made by HP. Here is a link to someone else's woes with that particular monitor. Good luck!
http://h30499.www3.hp.com/t5/Home-PCs-Pavilion-Presario/f1703-Monitor-Menu-stays-on-screen/td-p/557824
2helpful
Hi i have a problem in my hp lcd screen.Its HP L1906 (19'') ,the problem is that the Main menu pops up without pressing the menu button .And a black phrase in a small white box in the middle comes...
Press the menu button and navigate until find "factory reset" and select ansav/exit.
If you need more help post back!
Thumbs and testimonial are welcome!
2helpful
How to remove "no composite inpute signal"
If you have the same problem with both monitors, it sounds like a display card setting or problem.
The chances of you having the same problem with different units is 1- 50.
Try the monitors on a different PC and get back to me.
The osd main menu has appeared on my hp pavilion f1703 monitor
Control Panel->System->Hardware->Device Manager->Monitor. select and uninstall. Then let Windows detect the monitor and re-install the drivers for your monitor. Do the same for the disply adapter in the Ctrl Panel.
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
1helpful
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
8helpful
3answers
OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
3helpful
Blue Resolution Box
To turn off the reminder, use the buttons on the front of the monitor to do the following:- Press #1. Use down arrow to highlight Setup Menu and press #2. Use down arrow to highlight Resolution Notice and press #2. Select Disable and Exit.
Lg monitor won't come on
Try connecting the LG monitor to the VGA port on the HP tablet instead on the docking station.
Grand Canyon Tech
Grand Canyon Tech
