Question about Packard Bell Easy One Silver 2101 Notebook
Need to reset factory settings with no disc. its a packard bell hgl1 laptop.I,ve tried f2 and f8 and f11. ty.
rickyostrom
  • 270 Answers
SOURCE: Packard Bell Easynote MZ36 24 uk
You could search the internet for Bios Master passwords. Other than that, just pull the ac power, main battery and cmos battery and let the system drain.
If its a Windows password, then respond back for more instructions.
Posted on Nov 19, 2008
freetek
  • 5568 Answers
SOURCE: Packard Bell Easynote MZ36-U-024-UK
Just removing the battery briefly may not reset CMOS. Look for jumpers near the battery clip and if there are some, remove the battery, short any jumpers nearby. Failing jumpers, I would suggest leaving it without battery for at least a day; some are using 'supercapacitors' and a battery.
Opening a laptop case can be daunting; be advised that after you have removed any screws from the under- & back-side, the mating plastic parts may still have molded parts that will need to be popped apart. If the slits between the mating parts will accommodate it, an old credit card will sometimes avoid damage to the plastic, otherwise a putty (or spackle) knife will work.
Make sure you are not carrying any static charge before poking around inside; it can be a killer. Touch any exposed sheet metal or a heatsink to equalize any charge.
Posted on Dec 15, 2008
HarryHarley
  • 343 Answers
SOURCE: how do I know if my packard bell easynote R4250 is dead?
If the laptop is more than two years old. Time to replace the battery. The power meter is not a reliable way of seeing a bad battery. If just one of the cells in the battery is bad it will not run your laptop , and the meter still would show 100%
Posted on Jan 07, 2010
rew_info
  • 71 Answers
SOURCE: i have no drivers packard bell
Try DriverGuide.com - free accounts
Links info:
http://support.packardbell.com/pt/item/index.php?i=CS127B00&ppn=LX.BEU02.001
Specs and drivers
Posted on Apr 04, 2010
SOURCE: reset my laptop to factory settings
first of all press F2 or Del for cmos setting and there u can set the default settings of the laptop and check it options( i.e. F8=default settings) plz find the default setting option in ur laptop and then hit the defalut setting and ur laptop reset as factory settings.
ok dear!
Subham_05
Posted on Apr 09, 2010
Factory restore sfc00 no discs
Many systems have an option on boot - unfortunately not all are the same, typically F1, F2, F9, F12 etc, this allows you to restore factory settings.
Unfortunately you will probably have to kiss goodbye to any of your personal data unless you can get someone to 'pump' the disk first.
Jan 18, 2014 | Computers & Internet
How to restore packard bell easynote se to factory settings
There should be a menu when you press f7 or f9 during bootup (or f2 for some brands) when you access that menu, you should see an option to reaet your device back to factory settings
Feb 13, 2013 | Computers & Internet
What button do i press to restore factory settings
Dell XP = Ctrl+F11
Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. .
follow this blog-reset factory settings
If you need any kind of technical assistance ,you can contact support cell at http://www.vtechsquad.com
Sep 02, 2012 | Packard Bell iMedia Computers & Internet
I cannot start my packard bell..it hangs up into color blue when i launched start fix or start normally
Hello.
Either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive may roll back to that date.
To access System Restore in Windows 7: Open the Start Menu. Click on All Programs, Accessories, System Tools, and System Restore
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Jan 03, 2011 | Packard Bell Computers & Internet
Reset my laptop to factory settings
ok dear!
Subham_05
Apr 08, 2010 | Packard Bell Easy One Silver 2101 Notebook
Turn power button on and green lights flash once then nothing, bluetooth light just stays on, its as if its in hibernate
i have had this before with my packard bell was searching everywhere , look in your laptop manual if it came with one and their should be a few keys you have to press in order to get your BIOS settings or recovery on my laptop is it F11 but some could be ESC , F2 , F8
hope this helped ...
Apr 04, 2010 | Dell Inspiron 6000 Notebook
Easynote will not go past packard bell screen
You may need BIOS update. Check your CMOS time at bios page.
If time is wrong, set it up and try again. If this is solved the problem, change the CMOS battery.
JMC
Aug 15, 2009 | Computers & Internet
Packard Bell Easy One Silver 2101 Notebook Logo
862 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
