Question about LG Shine KE970 Cellular Phone
Music folder not accesible with shortcut keys
I would like to set a short cut key to go straight to the music folder. I can go to the folder right before the music folder but not directly into it. I have tried "music" but it goes to the online store instead. If I set it to "my music", it says "no application" Suggestions anyone?
    Brigadier General:
  • 7,752 Answers
Will have to check it out for you
Posted on Jun 13, 2008
I want to change what a key types e.g. the numeral 2 key has the @ sign but you need to use the ctrl key to get it. I want to use the shift key to get it.
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
also
http://www.snapfiles.com/get/mapkeyboard.html
freeware
MapKeyboard enables you to remap your keyboard and alter any key to function as a different one or optionally disable it as well.
The program can be quite useful for laptop users and people with keyboards that differ from the standard
hope this helps
Aug 22, 2012 | HP Computers & Internet
Tip
Shortcut keys
Some of the advanced features of windows allows shortcut keys these keys allow you to open applications faster this is a list of key combination and what they do the first set of shortcut keys and mostly designed for text applications such as notepad Microsoft word wordpad and any other text input application the first set of combinations keys are CTRL key and the letter C at the same time this allows you to copy highlighted text the next combination of keys are CTRL key and the letter V this allows you to paste that copy text you copy using CTRL C into text application or any application that uses keyboard input the next set of combination keys are CTRL P this allows you to print the current text document just as you would if you went file print the next set of keys are more designed for windows application shortcuts if you're on your desktop and you want to open the run dialog box that holds the windows key and press the letter R and you'll see the run dialog box here you can type in locations of files and open them through the run dialog box the next short cut key the allows you to open explore not to be confused with Internet explorer, that explore application is what opens up when you click on my computer my documents and the anything else to view folders files hard drives pictures movies and music or anything else that's inside a folder that the shortcut key to access this is the windows key and E at the same time it should open my computer because this is the main explore application the next key combination of more for advanced users CTRL+ Alt+delete this key combination accesses the task manager program which shows the process list the CPU usage and programs that are open and network activity this program allows you to end processes and programs that are frozen and do not recommend ending any processes that you're on not familiar with this may cause a computer crash or you lose data but ending application from the application view is OK if the applications is frozen because the computer will automatically end the applications processed for you safely as Microsoft has updated to windows Vista and windows 7 they'v added a new feature called the Arua effect if your computer is new or you have a compatible graphics card by pressing the windows key and the tab key at the same time will allow you to scroll through all the open applications in a 3D window this next set is mostly for laptops on laptops on the keyboard there's a key labeled FN which is short for function each laptop is different but in small print on the main keys you should notice little letters symbols or numbers are holding the function key and pressing one of these keys that have one of the symbols letters or numbers will allow you to access the secondary feature the keyboard as soon as you let go of the function key the keyboard returns to normal for example most computers will have a sun symbol on the up and down arrow keys this allows you to adjust the laptops brightness all you have to do is hold the FN key and press one of the arrow keys and you can turn the brightness of your screen up or down these are some of the few shortcut keys and you can do with windows there are many more hope this tutorial helps
on Jan 23, 2010 | Computers & Internet
I was assigning new products to my m202 keyboard however I accidentally assigned a product to the PLU list key. Is there any way to remedy this
Create a shortcut
hope this helps
Jun 07, 2012 | Computers & Internet
Unlock keypad
Create a shortcut
Shortcut Keys
Description
Alt + F
File menu options in current program.
Alt + E
Edit options in current program
F1
Universal Help in almost every Windows program.
Ctrl + A
Select all text.
Ctrl + X
Cut selected item.
Shift + Del
Cut selected item.
Ctrl + C
Copy selected item.
Ctrl + Ins
Copy selected item
Ctrl + V
Paste
Shift + Ins
Paste
Home
Goes to beginning of current line.
Ctrl + Home
Goes to beginning of document.
End
Goes to end of current line.
Ctrl + End
Goes to end of document.
Shift + Home
Highlights from current position to beginning of line.
Shift + End
Highlights from current position to end of line.
Ctrl + Left arrow
Moves one word to the left at a time.
Ctrl + Right arrow
Moves one word to the right at a time.
hope this helps
Jun 04, 2012 | Toshiba NB305-N410BL 10.1 inch Mini...
Short cut key of MS OFFICE and MS EXCEL Plz provide me short cut key
try doing this:
click on start then go to all programs.. highlight the program you wish to have a shortcut to your desktop.. right click your mouse then select send to desktop shortcut
Feb 22, 2011 | Microsoft Computers & Internet
ALL folder turned into shortcuts and i really don't know how to get back my stuff. You know the hard drive has music shortcut document shortcut. Somebody help me.
You must have had them all selected and then dragged them somewhere, then maybe dragged back, creating shortcuts at that location. This could be done accidentally by holding the ALT key (or if that key is stuck down) while dragging them back or by holding the right mouse button instead of the left. If it was the right-button thing though, you would have had to also left-click on 'Create Shortcut' on the menu that popped up.
If this is what happened your 'real' folders will be wherever you dragged TO and the shortcuts will be wherever you dragged BACK to.
The fact that there are shortcuts is not alarming. Your originals must be somewhere! Use the Search function to search for any file or folder name you can remember. Start at the root of the system (My Computer) to search everything; it could take a while so be patient. When you find the missing folders just select them all and drag back to where they belong (or Cut from current location, Paste in new location).
Feb 18, 2011 | Intel Computers & Internet
I am the new user, Kindly support me with out charging users guides on how to use ms word easily with short cut keys
Open up Word, click on Help >> MS Office Word Help and a whole bunch of online solutions will appear on the right side. Have fun.
For example:
About shortcut keys
You can quickly accomplish tasks you perform frequently by using shortcut keys - one or more keys you press on the keyboard to complete a task.
For example, pressing CTRL+B changes the selected text to bold, just as clicking Bold on the Formatting toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) or selecting Bold in the Font dialog box (Format menu) changes the selected text to bold.
Printing a list of shortcut keys
If you frequently refer to the Help topics that list shortcut keys, you may find it helpful to keep a printed copy of those topics. In Help, locate the topic you want, and then click Print .
You can also run a macro (macro: An action or a set of actions that you can use to automate tasks. Macros are recorded in the Visual Basic for Applications programming language.) that creates a list of the current shortcut key assignments, and then print the list.
On the Tools menu, point to Macro, and then click Macros.
In the Macros in box, click Word commands.
In the Macro name box, click ListCommands.
Click Run.
In the List Commands dialog box, click Current menu and keyboard settings.
Click OK.
On the File menu, click Print.
Customizing shortcut keys
You can customize shortcut keys in Microsoft Word by assigning shortcut keys to commands that do not already have them or by removing shortcut keys you don't want. If you don't like the changes you make, you can return to the default shortcut key settings at any time.
Using shortcut keys with different keyboard layouts or Word as your e-mail editor
Shortcut keys mentioned in the Help topics, menus, and dialog boxes refer to the U.S. keyboard layout. Keys on other layouts may not correspond exactly to the keys on a U.S. keyboard. If the language of the keyboard layout you are using doesn't match the language you set for Microsoft Word or Word Help, you may have to make adjustments when using shortcut keys or change your keyboard layout.
If you are using Word as your e-mail editor, some of the shortcut keys listed may not be available or may produce different results.
Dec 31, 2010 | Audio Players & Recorders
Hi wat is the shortcut to turning the blue tooth
hey brian
in this model there is no short cut for blue tooth as such but you can set a short cut by personalising your short cut keys like your joystick keys or even your selection keys.
hope it helps
Oct 03, 2010 | Sony Ericsson W350A Cell Phone
How do i remove music player from front page of my
1. go to phone menu.
2. go to setting.
3. go to shortcut.
4.go to left selection key and change and go to right selection key and change it.
May 29, 2010 | Samsung Lands Phones
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Dec 09, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
LG Shine KE970 Cellular Phone Logo
113 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
