Question about Sewing Machines
The bobbin thread does not get pulled through to the top
    Genius:
  • 1,788 Answers
Have you inserted the needle right, flat side faces rear of machine, Do you have a bent needle? Did you thread the machine with the thread going in the needle from front to rear? Is your bobbin threaded right? Did you leave a tail of 4-5 inches when you lowered the needle by the hand wheel turning it towards you? If all of these things check out, then go to your machine's customer service. You do not say what kind of machine it is, so I cannot give you any guidance on that.
Posted on Sep 16, 2010
Bernina sewing machine 1630.. Stitch won't stay in. Bobbin thread pulls out ???
Clip the top thread next to the spool. Raise the presser foot and pull the clipped thread DOWN through the needle eye. (Always remove the top thread in this manner. NEVER pull the top thread up!!!)
Now, ALWAYS RAISE the presser foot and rethread the top thread. Verify the thread path is correct.
Set the top tension to the midway point (then tweak the tension by testing).
If the bobbin thread is still pulling out, the top thread tension needs to be tightened. The tension is correct when the top thread and bobbin thread meet in the middle of the fabric.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 27, 2017 | Bernina Sewing Machines
Can anyone help me with an idiots guide on engaging the bottom bobbin
Are you asking how to pull the bobbin thread up? Simply hold the thread tail from the top thread and gently handrotate the handwheel toward you. One full circle completes one stitch cycle. The upper thread should hook the bobbin thread and pull up a loop. When that loop appears above the needle plate, gently pull the upper thread tail, enlarging the bobbin thread loop and catch it with a sewing tweezer, pin, or even the point of a scissor blade to pull the rest of the bobbin thread to the top.
How and Why to Bring up the Bobbin Thread
Nov 13, 2015 | Sewing Machines
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
The top thread does not pull up the bobbin thread
Is the bobbin thread through the needle eye? If not then it needs to be there. The top thread doesn't pull it.
May 07, 2015 | Bernina Activa 130
How do I fix the bottom bobbin thread
THE BOTTOM AND TOP THREADS ARE IN A TUG OF WAR. WHEN THE TOP IS TOO LOOSE THE BOBBIN WILL BE PULLING HARDER THAN THE TOP THREAD SO A GREAT DEAL MORE THREAD WILL END UP ON THE BOTTOM. TO CORRECT THIS YOU INCREASE THE TOP THREAD TENSION. IF THE TOP THREAD IS PULLING HARDER THAN THE BOTTOM THEN A GREAT DEAL MORE BOBBIN THREAD WILL END UP ON THE TOP. TO CORRECT THIS YOU WOULD LOWER THE TENSION ON TOP.
Dec 12, 2014 | Sewing Machines
How do i thread the bobbin through the bottom
Hello:
Thread the top thread and needle. Grasp that thread then use the hand wheel one entire rotation. Pull the top thread and you'll see the bobbin thread come up through the bobbin plate. Pull until the bobbin thread end is all the way out then slide/pull both threads to the back.
Mar 14, 2011 | Sewing Machines
How do I insert the bobbin into an Elna Lotus sewing machine (the old Lotus with flip sides)
Elna bobbins have holes on the top, so wind the bobbin with the holes on the top too. The Lotus bobbin winder doesn't have a tension device, thread just goes through an eyelet. So, place your scissors curved handle on top of your thread spool as it unwinds the thread to ensure the thread then winds onto your bobbin evenly. Also watch the bobbin fill and give the thread a nudge with your finger tip to fill top and bottom as well as the middle part, you want it to wind evenly across the full width of the bobbin. When full, pop bobbin winder back to left, cut thread and pull off the bobbin.
Then place the bobbin into the bobbin holder with the holes on top, and pull the loose thread tail around anti clockwise into the tension device and gently "click" it into the tension spring with the tip of your finger while holding the bobbin still with your other index finger.
You will be able to tell if it is in tension if you then pull the thread and it doesn't come out of the tension spring. It should feel firm with resistance but still release thread to a gentle pull. tally_girl_6.jpg Now thread the top down to the needle and holding the end of the needle thread, hand wind the fly wheel towards you to lower the needle and pull up the bobbin thread. Close the bobbin cover.
Always hold the two thread tails at the back of the sewing area as you start stitching a seam until you have stitched at least 4 or 5 stitches to avoid thread jams.
Lotus is a lovely vintage machine - there is a user group on Yahoo Elna heirlooms where you can find lots of info and pictures shared by members.
Dec 07, 2009 | Elna 8007
As Iam quilting with my macine the top stitches are ok, but back of quilt the thread is all boggled up-Tension ??
yes, this is a tension issue. Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 23, 2009 | Husqvarna Viking 1
Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Mar 16, 2009 | Sewing Machines
Can't bring up the bobbin thread
Sounds like hook/needle timing is off. Check it by doing the following with the power off:
remove bobbin, bobbin case, and needle plate.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins.
Make sure the bobbin is unwinding in the correct direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 27, 2008 | New Home HF-2022
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
