Question about Sylvania LC320SS8 32 in. LCD Television
Tv wont power on is there a reset button somewhere
    Genius:
  • 1,622 Answers
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out. hope this help in solving the problem.
Posted on Sep 16, 2010
Tv wont come on....samsung 50inch
replace the power supply board search:www. shopjimmy.com for parts
Feb 02, 2013 | Televison & Video
Turn tv off wont turn back on ! Model#32AV502R TOSHIBA
Notes from user manual: http://www.tacp.toshiba.com/tacpassets-images/models/37av502r/docs/37av502r_om_e.pdf
Unplug the TV for about an hour to see if it will reset itself, if not, try:
TV stops responding to controls:
If the TV stops responding to the controls on the remote
control or TV control panel and you cannot turn off the
TV, press and hold the POWER button on the TV control
panel for 5 or more seconds to reset the TV.
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
Press and open the Setup menu.
Highlight Installation and press . A new set of
Installation menu icons will appear.
Open the System Status menu, highlight System
Information
, and press .
Press tu to scroll through the menu bar to select
Factory Defaults.
Enter your PIN code (or 0000 if no PIN code has been set).
Highlight Yes and press . The TV will turn off
automatically after a few seconds. After the TV turns off,
unplug the TV power cord and then plug it in again to
complete the reset process.
To cancel the reset:
Highlight No and press .
Otherwise you may jhave bigger problem inside the TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 23, 2010 | Toshiba 32AV502R LCD TV
My ps3 wont change to hdmi gone through display settings and wont connect with hd tv says theres error somewhere any ideas how to solve this?
Hi, what you need to do is reset the video display. Do this by following steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you first press it, then again 5 seconds later. When you hear this second beep let go of the power button.
Step 3. Wait for your PS3 to start up.
Hope this helps and thank you for using FixYa
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
TV just went off and wont turn back on, Is there a reset button?
There is no reset button per say, try unplugging the tv for a few minutes and plug it back in again and see if it will reset. If not then you may have a component failure in your set.
Sep 02, 2009 | GE 27GT619 27" TV
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
TV wont stay on
no reset button on the tv maybe the tv is shock when you switch on the tv cause sometimes lizard always stuck down the pcb...try check the horizontal output
Dec 08, 2008 | Televison & Video
Tv stopped working, will not turn on, is there a reset button?
it can be fixed , it might be a fuse or a protection component or the power transformer but it will have to be tested to find the power problem.
Oct 07, 2008 | Protron PLTV-32 Television
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Tv is on but wont play
Resetting the TV
NOTE:
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Toshiba TV problem
No reset button, try unplugging the set for 1 min, the plug back in, otherwise Tv Tech time.
Jul 08, 2007 | Toshiba 36AX61 36" TV
Sylvania LC320SS8 32 in. LCD Television Logo
336 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
