Question about Garden
I need gas line routing diagram for weed eater max TE475Y TRIMMER
5 Suggested Answers
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 666 Answers
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Posted on Apr 13, 2009
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Posted on Jul 25, 2009
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
How to replace string on te475y
Hi jtl91370...
Try this solution...
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How do i repair a choke lever in a weedeater te475y gas trimmer? Does the lever pull straight out of the carburetor.
Upon inspection of this model machine, it appears that the choke lever shaft is pressed into place when the carb is manufactured. Removal may be possible, but probably more damage will occur. I have this same model machine with a Zama carb having flooding issues after soaking in a bath-type solvent overnight. This is NOT recommmended.
Here is a parts breakdown for your machine:
http://www.ereplacementparts.com/weed-eater-te475y-gas-trimmer-parts-c-17589_17626_18141.html
Unfortunately, there is no avaiilable release date for the part you need in question....On the page I made available it is part # A800 or A801...depending whether you have the Walbro or Zama carb. Mine has the Zama.
Jul 09, 2010 | Husqvarna Garden
I need a manual for weed eater max te475y twist n edge
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/te475y.html
I ran across your question when I to was looking for the manual. This is what I found it seems like the right one I will find out when I start working on the thing good luck!
Danielle
Jun 15, 2010 | Garden
I bought my TE475Y and last year and need to put new string on and cannot find manual. How is it secured? Thanks
This is most likely just put through a hole and tied off on the flywheel. Take it apart first. Then see how it is secured.
Aug 23, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Fuel hoses routed wrong on weed eater fuel tank
Apr 04, 2009 | Garden
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
201 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
