User manual for unidare r10 - Heating & Cooling
I have a unidare storage heater for some reason it is not getting as hot as it should do. All the elements are working
I'm also having a problem working out the settings, and I just found this link to an online instruction manual, whiuch seems fairly helpful.
http://www.unidareenvironmental.co.uk/83193-11.pdf
Lynne
Jan 05, 2010 | Heating & Cooling
Hello I have a Unidare night store heater that
ive just bought a house with unidare night stoarge heaters and one of mine hasnt worked - i found something on a site that said this:
"My Unidare storage heaters have a fused link (may be the wrong term ) that melt ever few years. Are you able to unscrew the top of the unit and look ( all turned off etc ) -A Fused link looks like an inch long piece of 5 mm solder - if yours has melted it will probably be in silver balls/blobs - replacing is easy if you have got to them."
so this could be why they arent working...
at night set the input to high (6) and output to about 3...in the morning set the output to 2/3 so a bit of heat will be released when at work, and then when you come in set the output to 6 (max)....should work! ive only just learnt what to do but ive they arent great!
Nov 03, 2009 | Heating & Cooling
Why wont my R10 work on battery power? The batterys are brand new? It works fine if i use the wall wart? How do u modify it to remove the cell block?
The manual for your Icom R10 can be downloaded here:
http://www.rigpix.com/icom/icr10_manual.pdf
Pay particular attention to pages 7 & 8, as they deal specifically with NiCad & Alkaline battery usage and the charge switch.
The modifications available for te Icom R10 can be downloaded here for free (registration is required):
http://www.mods.dk/index.php?ModelId=350&RadioRec=icom
Sep 29, 2009 | Icom IC-R10 Handheld Scanner
MY FORD TAURUS 1996 IS RUNING AND SUDENLY STOP AND IS DEAD, WHY.
tv1709~us~en~file=adobe.gif~gen~ref.gif Printable View (11 KB) Article No.
97-17-9
  • STALL - ON DECELERATION AND/OR INTERMITTENT STALL IN WARM WEATHER - VEHICLES BUILT THROUGH 8/18/96 AND SHO BUILT THROUGH 8/6/96
Publication Date: AUGUST 18, 1997
FORD: 1996 TAURUS SHO, TAURUS LINCOLN-MERCURY: 1996 SABLE This TSB article is being republished in its entirety to correct a service part number. CALIBRATION: 6-10A-R07, 6-10A-R10, 6-10A-R11, 6-10A-R12, 6-10S-R07, 6-10S-R10, 6-10S-R11, 6-10S-R12, 6-10B-R06, 6-10B-R10, 6-10B-R11, 6-10B-R12, 6-10T-R06, 6-10T-R10, 6-10T-R11, 6-10T-R12, 6-14A-R07, 6-14A-R08, 6-14A-R10, 6-14A-R11, 6-14S-R07, 6-14S-R08, 6-14S-R10, 6-14S-R11, 6LDA-JAD tv1709~us~en~file=caution.gif~gen~ref.gif WARNING: THIS MODIFICATION IS AUTHORIZED ONLY FOR THE LISTED ENGINE. PERFORMING THIS MODIFICATION ON OTHER ENGINE CALIBRATIONS IS UNAUTHORIZED AND COULD CREATE LIABILITY UNDER APPLICABLE FEDERAL OR LOCAL LAWS. ISSUE: Some vehicles may stall on deceleration and/or have an intermittent stall in warm weather. This may be caused by the vapor control valve not supplying a steady flow of fuel from the tank to the intake manifold.
ACTION: Replace the fuel tank, vapor control valve, fuel fill tube cap and clamp. Install heat shield over fuel tank and reprogram the Powertrain Control Module (PCM). This should reduce the possibility of stalling. Refer to the following text for details.
Perform all diagnostics for stalling by following the procedures outlined in the 1996 Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual and 1996 Taurus/Sable Service Manual, Pages 03-13-5 through 03-13-8. Check to be sure Grounds 401 (sedans) and 400 (wagons) are secure. Check for a kink in the canister vent hose and repair as required. If no other concerns are found, reprogram the PCM using the latest level CD-ROM update disc and refer to the following PCM Application Chart for correct PCM usage. Replace the fuel tank, vapor control valve, and vapor management valve by following the procedure outlined in the Instruction Sheet included in the Fuel System Service Kit.
PCM APPLICATION Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 6-10A-R07,R10, R11, R12 F6DF-BF 6-10A-R12 F6PF-CVB 6-10S-R07,R10, R11, R12 F6DF-DF 6-10S-R12 F6PF-CYB 6-10B-R06,R10, R11, R12 F6DF-JD 6-10B-R12 F6PF-CXA 6-10T-R06,R10, R11, R12 F6DF-KD 6-10T-R12 F6PF-CZA 6-14A-R07,R08, R10, R11 F6DF-EG 6-14A-R11 F6PF-CGA 6-14S-R07,R08, R10, R11 F6DF-FG 6-14A-R11 F6PF-CFB 6LDA-JAD F6DF-RD 6LDA-JAD F6PF-CDA
Sep 01, 2009 | 1999 Ford Taurus
Need manual
you can download your manual from the following link -
http://safemanuals.com/user-guide-instructions-owner-manual/RAYMARINE/R10%20RADAR%20SYSTEMS-_E
post further comment if you have any problem related downloading the manuals....
Good Luck!!!
May 06, 2009 | GPS
Toshiba R10
it might seem that the other user has a limited account and maybe the driver of the pen function is limited only to the administrator.
Rusty;
Hallel Computer Enterprise
baguio city philippines
Jun 08, 2008 | Toshiba Satellite R10-S802TD Tablet PC
How to read dvr messages
From the R10 user's manual:
From time to time DIRECTV may send you messages about updates to your service and other important notices. These messages are important, useful, and easy to find. When your DIRECTV® DVR receives a new message, a message icon ( ) appears on the channel banner and in DIRECTV Central.
To read a message:
1. From DIRECTV Central, select Messages & Setup.
2. Select Messages.
3. Select the message you want to read.
Use the CHAN DOWN button to see text that does not fit on the screen. When you are finished reading a message, select Done or Delete Message. Selecting the message icon in the channel banner will take you to your list of messages. The message list will display “No Messages” if there are no messages to read.
You can download the full user manual for your R10 here.
Oct 19, 2007 | Directv R10 TV Receivers and DVRs
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
