Question about Arris SURFboard SB5120 Modem
My Motorola Modem keeps flashing the DS light.
Why does link light keep flashing blue
It is connected to your modem via strong connection.
Contact ARRIS Support for more details.
Mark
Motorola Support
Jun 04, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Ngv510 red light blinking
hello i was wondering if anybody can help me out here,recently my att unverse dsl nvg510 modem redlight (wifi setup ) is flashing red and sometimes flashing green. my internet is running good, all the device that connects to wifi is good also. and also i unplug the power for few minutes and plug it back in and still that redlight keeps on flashing. nobody can answer my question. thank you
Jul 29, 2012 | Arris Nvg510 At&t U-verse Modem Gateway...
Receive and send lights keep flashing and no connection can be obtained
Reset the modem by removing the power for at least 45 seconds,try to get online.
If you have a router, reset that also. Modem first, then router,in sequence.
Check the cable going to the modem for any cuts or connector is loose.
If it still won't work ,replace the cable.
Lastly, call your Internet provider.
Nov 27, 2010 | Arris SURFboard SB5101 Cable Modem
My modem is not connecting right.
Theres a small reset button at the back of the modem. You will need a pencil or a pen to press it. Press that button, hold it for at least 10 seconds and see if it works.
If it doesnt, unplug the modem for around a minute, plug it in and try again.
If the problem still persists, something should be wrong from the internet provider. Contact your ISP. Hope that helped.
Apr 02, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
"Send" and "Receive" lights are flashing on the modem
This is a sign of a bad modem already, but you can still try to fix this by doing a firmware upgrade on the unit and you can get the firmware from the manufacturers web site and then if still have the same problem have it replace....
Dec 07, 2009 | Arris SURFboard SBG900 (49402201900) Modem
My Motorola Sb5101 modem will not let me access the internet, the send light constantly flashes and i can't attain any internet connection.
If you have the following lights :
Power light - on
Receive light - flashing
Send light - flashing
Online light - off
PC/Activity - on
Standby - off
Then your Network Access is OFF - modem is successfuly registered but Network Access Control is disabled via DOCSIS configuration file.
Call your internet service provider....
Nov 06, 2009 | Arris SURFboard SB5101 Cable Modem
Motorola modem sb5100 lighting up good all the way except for pc/activity light flashing at a faster rate then normal, is my modem bad?
Check if your computer is downloading anything from the internet / doing any windows updates. Often all this means is that it's busy downloading stuff. So long as it's working and not overheating I'd say that your modem is fine.
Aug 04, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SB5100 Cable Modem Power Lght Flashes
Call your Internet Service Provider.
They can remotely "connect" to the cable-modem, and diagnose it.
Jul 16, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Can't find WEP key for DS
You can see the WEP key at the side or bottom of your modem. Its the 10-digit code. If it is not listed there, you need to access the Setup Page of Motorola modem. Go to internet explorer and type http://192.168.1.254
Jan 20, 2009 | AOpen AOR-401M Router
'How to fix flashing Power light on modem SB5100?
Check with your server.The registration details have been deleted.
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SURFboard SB5120 Modem Logo
432 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
