I have a NEC plasma tv which until recently played dvd/videos etc without problems. It then have lines going across the screen and sometimes just black out on the screen. We had the dvd/video player serviced and it still does the same thing. We have replaced the cables and also same problem. Were using the AV1 port, and tried the AV2 port but no difference. Tried to use the Wii and that also is doing the same thing?? The tv is approx 2 yrs old.
    Genius:
  • 1,622 Answers
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable.
Hope this help in solving the problem.Take care.....
Posted on Sep 16, 2010
We have a 50" Vizio plasma TV with a persistent blue, sometimes white, pair of vertical lines on the right side about 1/4 from the right edge.
if those problems were present when you got it back from repair, then, the guy didn't fix it fully.
if those are new problems - then you are now finding out why electronics and plasma displays wear out after ten years, replace the unit, don't pay to 'get it fixed' as the rest of the parts are old and about to also fail.
Mar 25, 2018 | Vizio Televison & Video
Hi i have a telefunken tv it plays normal but it has black strips on the screen from the middle to the bottom,what could be the problem
PLASMA seems to be what you are describing...
(even Sears sells those parts).
There are some packs... sometimes a mere reseat will fix the problem...
Problem is... you can do way more damage without ESD protection... & ruin the entire set...going in carelessly.
Please do look at the anti-static wrist band
(even tampatec admits he smoked some stuff with a tiny STATIC spark...!!).
Go on-line (I'll post him below) the a young fellow "tampatec"
tampatec black lines Bing video
TV Parts Universal TV Stands DLP Chips ShopJimmy
Apr 29, 2016 | Televison & Video
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Plasma Burn IN
It's actually similar to the old screen burn in you'd see on very old CRT televisions and monitors. You can play your playstation on it, just make it a point not to leave it on the same screen for long periods. For instance, if you pause the game, turn the TV off until you're ready to continue.
Plasma Burn In only happens if you leave the same image on the screen for an extended period. Just don't do that, and you'll be fine.
-John
Feb 07, 2008 | Sony Playstation 3 (PS3) Console
Sharp 2002
If you are using an analogue signal then check things like DECT phones, Wifi / DSL modems, power cables, power convertors / UPS, washing machines, dryers, microwaves etc are kept as far away from the cables as possible.
Have you bought anything new recently, when it happens think what things are turned on... is it the garage door being opened etc.
If you are using a digital signal (and ideally something like a DVD player or a games console rather than a cable TV box) then check the HDMI cable.  If all appears well then it could well be a fault with the television, especially if you get interference from multiple source (i.e. cable TV, DVD player, console etc)
Oct 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips flat screen tv
It may be a problem with a cheaper HDMI cable. If the cable is too long or if the cable is of a cheaper quality, you may be able to solve the problem with a larger and shorter "pipe"
Sep 03, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Jan 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
