Question about EnGenius EOC-3220 (EOC3220)
192.168.1.1?????? What if this IP address (192.168.1.1) doesn't work on my product.
  • johnsamsky May 17, 2008
    Yes. I'm having trouble getting into the router. I can't even get to the point where I setup the router. I changed the IP address for the router under internet protocol to 192.168.1.10 and when I open internet explorer and type in 192.168.1.1 the router will not show.
  • Anonymous Nov 26, 2008
    tylped in the address or supposedly address of my new router and IE would
    not go there. is there some other way to access this site. I can't seem to make this router work
Everything you need to do is to write 192-168-1-1 dont work on the address bar on your own preferred browser and push enter. It usually is to your greatest benefit to utilize browser with maximum assistance for net requirements (for example Firefox) to get the best effects. You'll be taken up to what's critically the computer software which drives your current networking piece of equipment. At this point you possibly can make corrections to configurations, set your account details, and setup your computer network machine as you think fit.
As it is the fact with any computer system setting, it usually is to your greatest benefit either to get a whole copy of your own adjustments prior to modify them or put down the defaults for every single function which you modify. A number of erroneous configurations when making your own computer network tool and you might remove your internet connection.
If a specific thing truly does fail when modifying your computer network piece of equipment via the private IP, there's typically a hardware reset switch on the backside of the unit which can recover the configurations on their facility defaults.
Posted on Jun 05, 2012
Pls anyone wit an idea.. i cant get into my Engenuis radio. i mistakenly changed th ip to 192.168.1.1 to 172.16.7.1 and it rebooted after which the log in page don't show again.wht can i do nw..??
Posted on Apr 21, 2011
  • 667 Answers
Hi john - the address 192.168.1.1 is the default address of your router. Your pc that you're using for setup is supposed to be set to 192.168.1.10. with subnet mask 255.255.255.0 . Are you having problems getting in to your router? Do not enter anything for the default user and password. Let me know what problems your having. Thanks.
Jeff
Posted on May 17, 2008
2 Suggested Answers
contratek
  • 83 Answers
SOURCE: do you have internet explore ip address. it starts
open a browser and type
http://gateway.2wire.net... and the home page will open
or try 192.168.1.254 and this will get you in
Posted on Mar 05, 2010
When I type the ip address http:192.168.0.1 in and hit enter like it said to do it doesn't ope the admin. window it just opens the all the web pages for that ip.
This is an internal network IP address, it doesn't go any further than your own local network (LAN).
Are you sure that is the IP for the router? If you provide the name and model number for the router, I can tell you if your address is right.
Routers usualy have 192.168.1.1 as IP adress. other options are:192.168.1.100192.168.100.1
Feb 18, 2012 | NetGear Computers & Internet
I am trying to figure out how to connect my Linksys WRT54GS2 router to my Hughesnet HN9000 modem. I have already attempted what hughesnet website told me to do and it didn't work. I have it set up...
DHCP and static IP are two different things. DHCP assigns IP addresses, and static Ip just means that the IP address stays the same, and is not dynamic. You probably need to reset the modem to accept what it sees as a :"new" router. Turn off both router and modem. Restart the modem first, give it a minute to boot up, then turn on the router- in that order. It should be ok now.
Mar 11, 2017 | Cisco Linksys WRT54GS2 Wireless-G...
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it.
1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer.
2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following.
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses.
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
Thank you for choosing FixYa! have a good one!
Aug 05, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Wireless does not seem to work any suggestios
Go to HP Wireless Printing Center.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I want serial key the hide your ip address product
Such software products do _NOT_ work -- your IP-address is needed so that any "responses" to TCP/IP packets that you "send" can be delivered "to" your IP-address.
Nov 15, 2010 | HideYourIPAddress.net Hide Your IP Address
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
My WL-138G cards loose connection info when shutdown
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 27, 2009 | ASUS WL-138G Wireless Adapter
Ps3
U NEED TO RECONFERM your internet conection with your PS3
Sep 13, 2008 | Sony Playstation 3 (PS3) Console
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
EnGenius EOC-3220 (EOC3220) Logo
444 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
