Question about Smeg FAB32 Bottom Freezer Refrigerator
How to replace light bulb in fridge ? - Smeg FAB32 Bottom Freezer Refrigerator
  • 51 Answers
Open the plastic gaurd by lifting it up and then remove the old buld by threading it down. now replace it .
Posted on Sep 16, 2010
?y light is out and I don't know where the light is so I can replace it. I can't find my manual. Model number: GX5FHDXVTOO. WHIRLPOOL FRENCH DOOR
There should be a plastic grille mounted on the ceiling of the fridge, usually, a good tap with the palm of your hand, towards the rear of the fridge will pop the grille loose and expose the light bulbs. Be sure to replace the bulbs with 40w appliance bulbs only! if replacing the bulb doesnt work, you may need a new light switch or the metal tab in the bulb socket may not be contacting the base of the bulb properly...
Apr 25, 2016 | Whirlpool Refrigerators
How to change a light bulb in a diplomat fridge
I Googled Diplomat Fridge light bulb and came up with this: Copy www.youtube.com/watch?v=U-yyPGlRoZ0. Go down the page until you come to a video called "How to replace a fridge light bulb". It is there, you have to look.
Jan 02, 2015 | Refrigerators
The freezer light doesn't come on but we tested the bulb elsewhere and it works.
Moisture can contribute to a bit of rusting at the point where contact is made between bulb and socket. Unplug fridge. Use a small piece of fine-grit sandpaper on the socket where the bulb will connect and then spray a tiny amount of WD40 to the socket. Let it dry for a few minutes. Replug your fridge and screw in the bulb. This works for fridge lights too and I've noticed whenever I have something like a cut melon in the fridge which causes condensation then my bulbs will go out and I have to do this sand and spray thing.
Sep 09, 2014 | Kenmore 26.7 cu. ft. French-Door...
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
Light not working in Maytag Plus 134A Refrigerator
Sure you've got power to the bulbholder? Check the switch
Sep 04, 2012 | Maytag Refrigerators
I have a Hotpoint HMB313I integrated fridge freezer. When I open the fridge door no light comes on. Should there be a light in the fridge? If so, could you tell me please where the light(bulb) is located...
Hi!!
The light bulb is usually located in the center top of the fridge box, you may need to get on your knees and look up to see it. They usually just screw out, in case there is a plastic cover, just squeeze it and remove it. The replacement bulb can be found at Walmart or KMar it is call Appliance Bulb.
Good Luck!! Don't forget to rate this post!!
Jul 18, 2010 | Hotpoint Refrigerators
Refrigerator section light broke. Replacement
Immediately when you open the fridge door the light has to go on,if it is a screw bulb,just tighten it little while'
if pin bulb push it harder,finally you may have to change
the bulb handle in the fridge.
May 12, 2010 | Maytag MTB2176 Top Freezer Refrigerator
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Smeg FAB32 Bottom Freezer Refrigerator Logo
121 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
ashburton
Mike
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
