Question about Autodesk AutoCAD 2010
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
    Top Expert:
  • Autodesk Master
  • 14,162 Answers
Http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Posted on Jun 22, 2015
2 Suggested Answers
Mongkey
  • 236 Answers
SOURCE: While Removing AutoCad 2006 :FATAL ERROR:
This error could be occuring due to the fact that the Application is targetting a dll from an older version.
Uninstall all versions of Revit and Reinstall Revit Architecture 2011 as per the link below:
http://usa.autodesk.com/getdoc/id=TS13712572
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Posted on Feb 03, 2011
Find problem in Autocad 2014 while opening a file Fatal error: unhandled delayload "modlr19.dll"Module not found exception at 75bad36fh
Try uninstalling and then run CCleaner to remove any tombstones left over in the registry. Once clean try a fresh install once again.
Nov 25, 2014 | AutoCAD LT 2014 for PC
Fatal error: unhandled e06d7363h exception at 7618c41fh.. What is this and how do I fix it???
Try checking in with the AutoCAD Community for additional visibility and potential solutions.
Philip
AutodeskCare' Community Manager
TW l PI l YT l BLOG
Oct 16, 2012 | Autodesk AutoCAD 2002 for PC
While Removing AutoCad 2006 :FATAL ERROR: Unhandled Delayload "pm8.dll" Module Not Found Exception at 7c81eb33h
Mongkey
Feb 03, 2011 | Autodesk AutoCAD 2006
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
Fatal error
this error points to locked files during startup, only known to me solution is complete removal of autocad from the system, it as well be indication that insufficient or faulty memory in the system.
i would suggest removal of autocad, reboot, install ccleaner, remove of all junk and clean of registry, then clean re-install of autocad,
if you have less than 512mb ram on winxp or less than 1024mb ram on vista, it can be a problem as well.
Jul 26, 2010 | Autodesk AutoCAD 2006
Unhandled e0434f4dh Exception at 7c812a6bh. cannot run AutoCAD software.
Try to uninstall any version of .NET framework installed on the system and install latest version of .NET. You can try to install 3.0 version.
Oct 01, 2009 | Microsoft Windows XP Professional
Unhandling error
How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Question : How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Answer : To correct an Unhandled Exception error received while editing a scan:
  1. Open the Control Panel on your computer and double-click Display.
  2. From the Display Properties window, click the Settings tab, and then the Advanced button.
  3. From the "DPI setting" drop-down list, select Normal size (96 DPI).
  4. Click OK and close all open windows.
  5. Restart your computer for the changes to take effect.
May 04, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Autodesk AutoCAD 2010  Logo
1,469 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
