Paper will not go through machine when copying or faxing
    Problem Solver:
  • 18 Answers
Unplug it tip it upside down and run you hand in the spot where the paper goes to check for any item in the way of the paper
Posted on Sep 16, 2010
The outgoing faxes are becoming unreadable, any idea as to why this is occuring and what we can do to fix it?
I will look it up in the morning, I don't have that information with me at the moment, But there is a scanner calibration you can do to correct it.
You have to enter some codes and simply run white paper through the scanner to reset the values. But off hand I can't remember the exact numbers. I will get look them up and send it on here.
It is not hard to do at all. Will take about 2 or 3 minutes.
Jan 11, 2010 | Xerox FaxCentre F116 Plain Paper Laser
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Hp1040 fax and copy machine
I solved this problem by returning my fax machine to where I purchased it and exchanged it for another type of hp machine and it automatically goes in long format when it scans long format paper. If it scans short letter form, it automatically copies itself and adjusts itself. Thank you aniway, durl
Nov 25, 2008 | HP 1040 Plain Paper Inkjet Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Fax problem
How is the copy when you try to just make a copy of something? If it copies good, then it might be the senders machine.
If when you make a copy, and the copy is blurred, then it is probably your ribbon/ink cartridge.
If it is the cartridge, just replace the cartridge, and you should be good to go.
Hope this solves your problem.
Good luck.
Mac =)
Feb 09, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Copies with the Brother Fax-T104
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Dec 21, 2007 | Brother FAX T104 Plain Paper Thermal...
Copying
you place the paper in the same place as if you were faxing and the paper it's printer in the rear most carrier, but one press of the button indicates you want one copy, pressing it again should then do one copy.
Aug 11, 2007 | Brother FAX-575 Plain Paper Thermal
Copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
14 people viewed this question
 Grubhead
Grubhead
