I have a wireless router and it works fine, but it is unsecured. How do I set up security ?
  • 3,940 Answers
Securing wireless is a pretty simple process.
You can access your router by opening a IE browser page, then typing the default gateway IP address on the address line. In my case, my router is a Linksys. The default gateway is
Once you type that in, you will get the login prompt for the router. In general, the default user name and password is USERNAME left blank, PASSWORD admin the reverse, or admin for both. If those don't work, check the documentation for your router.
Once you access the router from the browser, you will have an option for Wireless, and in that option to enable security.
Currently, the most popular type of encryption is WPA-TPIK
Select that oprion if available, then select a passphrase. Personally, I suggest an old phone number you recall from your youth, it is 10 digits, and hard to associate with you but easy to remeber. Once you set encryption and the passphrase, save the settings and exit the browser.
When you try to connect to the network again, you'll be prompted for the passphrase, and a confirmation. Once entered twice, then you'll connect and have a secure connection.
Other suggested security items once security is enabled:
1. Change the login and password of the router (Done in the same router setup as the security)
2. Disable the SSID broadcast once the network is configured (Don't advertise the network)
Some web links on wireless security:
Posted on May 17, 2008
How do we secure our Wireless router Up until we have been using a cable router and now wish to use a DSL-G604T model which is up and running but in an unsecured mode.
1. Navigate to router's web interface<br /> 2. Login, click to Wireless button<br /> 3. Select WPA radio button as Security<br /> 4. Select Pre-Shared Key radio button and type some password to PSK String field<br /> 5. Click Apply button<br /> 6. To save and reboot the Router, click on the Tools directory tab and then click the System button. In the System<br />Settings window, click the Save and Reboot button under Save Settings and Reboot the System<br /> <br /> DSL-G604T doesn't have built in MAC access list and may hang on heavy usage. To optimize it for stable and safe connection use Router Commander program from <a href=""></a>, with it this router shows very good <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: HE">performance </span>and stable internet connection.
Aug 17, 2010 | D-Link DSL-G604T Wireless Router
I cannot set up wap security for wireless d-link g604t. everyone can connect without password. -
user manual above it shows you how to do it in the security section. Basically you loginto the router give logon and password, then go to security and set a WAP/WEP "Key" All in manual above..
Jun 01, 2010 | D-Link DSL-G604T Wireless Router
My Router works only if I do not put security password on it.
The router works only if the network is unsecured.
When you secure the wireless network , make sure that you will change the wireless network name also. Because if you change the wireless security and if you keep the same network name then your computer will try to connect to the same network name with the old unsecured settings saved on the computer.
Try to change the SSID ( network name ) and security to WPA, check if that works.
If that doesn't work then I believe you will need to upgrade the FIRMWARE of the router.
Click here for more information about the routers and the wireless network
Jan 25, 2010 | Belkin Computers & Internet
I can't set a password on accessing DSL-G604T wireless router.
you want to secure the wireless network.
Is there any computer connected to the router with the ethernet cable ?
If not then you will need to connect the computer to the router with the cable.
check the ip address on the the set up page of the router.once you open the router setup page, you will find the option to make it secured.
Click Here for more info
Nov 05, 2009 | D-Link DSL-G604T Wireless Router
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
Secured connection is gone and all we have is Linksys unsecured
Next time try unplugging the router for 30-60 seconds then plug it back in. Should resolve minor glitches like this one.
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
Unsecured home network
Here is a nice tutorial about setting security on your wireless network
Also, your router's user guide is available at
If you feel like reading more, there is a nice tutorial posted by Microsoft also
Let me know if you run into any issues and I will be happy to help, good luck :)
Nov 01, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
