Question about Garden
I am rewireing a dayton single phase10hp 4 capasator start-up 220v electric motor can you give me good wireing diagram
  • 43,501 Answers
Dayton motors are sold by Grainger their website is www.grainger.com
For repair help you can go here
on the top right there is a 800 number for repair help... they would be the best people to call to help you get the diagram you need...
heatman101
Posted on Sep 16, 2010
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
How to change Emglo air compressor from 220v to 110v. Compressor is running at half speed when plugged into standard wall outlet. I bought the compressor new in the early "90's" and since then...
Hi Pete,
On the side of the motor on the label should be a wiring diagram. The diagram will tell you how to wire fro high 220v and low 110v ...
If the nameplate is single voltage only then the motor cannot be rewired for the lower voltage...
Also check the motor RPM nameplate as compared to the others...you may have a 1725 motor and the newer ones a 3450 motor...that would give them double the RPM's if the gearing or pulley sizes are the same...so.. if you have the right voltage and the RPM's of the motor are the lower, then you possibly could change the pulley sizes to speed up the compressor...
Lots to check and think about...
heatman101
Mar 11, 2011 | Dewalt Air Tools & Compressors
I need help wiring a Delta 28-280 model bandsaw from 220v to 110v. The saw came 110v from the factory, but the previous owner re-configured the wiring to 220v. I need it back to 110v. Thank you.
Rewiring the motor isn't hard, but be aware that you can hurt/kill yourself if you mess this up.
That said, manual is here.
Before you start, make sure you have a couple wire nuts (orange & yellow are a good sizes), a replacement plug, and some electrical tape.
1.) Unplug the cord from the wall. Go ahead and remove the prongs since you're going to need to switch it back to a 120V type prong adaptor. Don't put new prongs on until you've got things rewired. This will help keep you from accidentally electrocuting yourself.
2.) Open the saw base and have a look at the motor. There's a cover held on by a single screw. There should also be a wiring diagram on the motor that looks something like:1aa0c59.jpg
3.) When you remove the cover you should see three groups of wires. There should be numbers on the wires, but you can also figure them out by looking at the number of wires grouped together (see wiring diagram).
4.) You want to change from three groups of wires to two groups of wires per diagram, so when you're done, 1,3, & 5 should be grouped and 2,4, & 8 should be grouped. This is assuming your wiring diagram matches mine.
Make sure you don't have any exposed copper (cover w/ electrical tape if necessary). Make sure you have the wirenuts screwed on securely. Make sure you close the cover up and put the screw back in reasonably tight.
Put the prong on the wire, plug it in, and hit the start button. If you did everything right, it will start right up and no breakers will trip. If you goofed a pair, your motor may spin in the wrong direction. Otherwise, enjoy.
Jun 04, 2010 | Saws
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Electric motor is not functioning properly
Sounds like its wired for 220v and the start capacitor is shot.
Mar 24, 2009 | Saws
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
