Question about EliteGroup 661FX-M Motherboard
WHERE IS THE JUMPER TO CLEAR COSMOS - EliteGroup 661FX-M Motherboard
    Scholar:
  • 181 Answers
Locate the CMOS Battery. Near the battery, you may find 2-pin that maybe labeled as CLEAR CMOS. Short circuit the pins for a couple of minutes. Just be sure that your PC is OFF when doing the process.
Good Luck
TedMac
Posted on Sep 16, 2010
What is the soundtrack for Cosmos 1980?
Cosmos, (Main Theme), Composed by Vangelis
Sep 04, 2016 | Cosmos (1980)
How old do you think a kid has to be to appreciate cosmos?
first watched Cosmos when I was 12. My mom found the VHS tapes and we all watched it together... I remember that I liked it a lot, but looking back I don't think I truly appreciated it for the masterpiece that it was. I would say that a freshman in high school would be old enough to fully appreciate this series.
I have a celestron Cosmos 90 GT Wifi telescope and so far haven't been able to use it. I struggle with aligning the telescope to 3 bright stars... if by chance it says its aligned when I choose a star
Aligning a scope requires several things to be correct.
1. You must follow the setup in manual 100%
2. You must pick the correct alignment stars. Most failed alignments are because you aligned on the wrong star. So alignment requires you to learn the names of a few bright stars and be able to spot them in the sky.
3. With many goto scopes there might be a "home position" to start the alignment. For example, tube pointed roughly North, and level. Check your manual for a "home position. Also time, date, and site must be correct.
Clear skies,
TelescopeMan
www.telescopeman.org and www.telescopeman.info
Feb 16, 2015 | Celestron COSMOS 90GT Wi-Fi Refractor...
Jumpers
Remove the jumper plug from the CMOS jumper (CLEAR CMOS) pins 2 and 3. Place the jumper plug on the CMOS jumper (CLEAR CMOS) pins 1 and 2 and wait approximately five seconds. Remove the jumper plug and replace it on the CMOS jumper (CLEAR CMOS) pins 2 and 3
Apr 27, 2014 | Computers & Internet
I would like to obtain a user manual for the LG Cosmos phone
Hi leo114,
Click HERE for the manual of you LG Cosmos Touch.
Hope this helps
Feb 23, 2011 | Cell Phones
Bios can't run after clear CLRTC
If you used a jumper to clear the CMOS, be sure that you put the jumper back like it was or the computer will not boot up. Normally that jumper will be on pins 1 & 2. To clear the CMOS, you pull the battery out and put the jumper on pins 2 & 3 for a couple minutes. Put the battery back in and put the jumper back on 1 & 2.
Apr 05, 2009 | ASUS P5GD1 Motherboard
HARD DRIVE INCOMPATABILITY ISSUES
I evidently figured this problem out on my own. Because I pulled these two drives apart and they were part of a two disc array, the 3Ware Raid controller assigned one as "master" and one as "slave". So, even though they will appear as perfectly good hard drives to ANY pc and you can load an O S on them, they will read as either a slave or master upon hard boot-up. There are two ways around this. One--you can leave them in your pc and "delete" the array in the BIOS and then re-format them, or Two--before or after you reload your O S, power down and unplug your pc. Then pull the COSMOS battery out and reset the "clear cosmos pins" on the motherboard. Leave the battery out for 3 to 5 minutes and then re-install the battery and re-set the "jumper pins" back to their original position. Ofcourse, if you had any overclocking settings previously set in the BIOS, you will have to set the parameters of your choice once you re-boot. It actually takes longer to write this explanation than to do the deed. Problem solved.
Feb 27, 2009 | Western Digital Raptor X WD1500AHFD 150...
Big problem
to clear cosmos(reset bios) remove rtc battery for a few minutes then replace ;restoring bios to factory set.
battery looks like large digital watch battery.usually located(but not always) underneath keyboard.
Mar 18, 2008 | HP Compaq nc6320 Notebook
EliteGroup 661FX-M Motherboard Logo
99 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
