Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to install win xp in toshiba u300... it will show harddisk not found, bios also i am not identify any mode. i think it is retrusted by toshoba software ... Please tell how to do...i need xp........thanks
  • 34 Answers
It may be because of different format of your harddisc window xp recognise only FAT and NTFS format format your harddisc with these two format then try to install xp
Posted on Sep 16, 2010
When I will going to install win xp(sp2) with sata harddisk its show no dsrive installed on your system
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 15, 2011 | MSI MBOX K8MM-V Athlon64/Sempron Barebone...
Hi! sir, hw r u. when ever i try to install win
If you don't care about data on the hard drive format the drive first and then install XP. You may also find that your XP CD is bad in this case try different disc if possible. Good Luck.
Apr 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
I cnt install win xp on my toshiba u300 laptop .....when i start installing window xp on my toshiba u300 there came that it didnt detect any hard drive on computer ... plz tell if u hav any solution 4...
If your laptop is like mine, it'll have a setting in Bios that needs to be changed in order to support XP.
In my laptop, there was a setting called Native SATA driver or something similar of that nature.
It took me quite some time to go through forums in order to find that out. Once that setting was changed, the notebook found the hard drive and I was able to install Windows XP.
Mar 27, 2009 | Toshiba Satellite U300-ST3091 Notebook
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Hi there... i can`t install win xp. it said not detect harddisk on CPU.
Check in the bios whether harddisk is found.If yes which chipset you r using.Accordingly you have to install the raid driver to enable hard disk to make enable.
Jan 04, 2009 | Gigabyte GA-8S648FX Motherboard
Problem on loadind windows xp on hp pavilion dv2000 laptop
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Nov 29, 2008 | HP Pavilion dv2000t Notebook
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Install windows XP on toshiba satellite U300
Hello
The windows Xp installation doesent find your hardrive because you have a sata drive. you need to adjust the settings in the bios so the sata drive appears as a ordinary IDE drive(ide native) or something like that. search in the bios settings.
A other way is to burn a new winxp cd with the Toshiba Satellite U300, sata drivers.
download the http://www.softpedia.com/get/System/Back-Up-and-Recovery/Barts-PE-Builder.shtml
and download the toshiba harddrive drivers and creat a new cd.
but the simples way is to make the change in bios.
good luck
Aug 18, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
