I successfully installed my dlink router to my computer. it shows im connected to the internet but shows an exclamation point on my wi-fi signal. it says that i have "no internet access" what am i doing wrong?
smeago1
  • 136 Answers
SOURCE: laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Posted on Jan 03, 2008
honey2509
  • 146 Answers
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
patemi
  • 366 Answers
SOURCE: cannot install access point dwl 2100
Visit the emulation wizard and simulate settings according to Quick Installation Guide
Posted on Jan 26, 2009
SOURCE: I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
Posted on Feb 24, 2009
Young-Leigh
  • 11 Answers
SOURCE: i have problem with the wi-fi network adapter.its
If it is a F500, it is a common fault with the series. The manufacturers warranty was increased to 2 years, and the wifi is covered. The motherboard will need to be replaced, so give HP a ring, or contact the store that you bought it from, and they should be able to help.
Posted on Aug 16, 2009
I have a Roku in my bedroom & when I try to watch Netflix it just spins & spins & takes forever to load. Once it starts, it stops & starts spending again.
First step, of course, is to unplug the Roku for 10 seconds then plug it back in again and let it connect.
Assuming a Wi-Fi connection is what you are using, it is possible (likely) that your Roku is too far from the Wi-Fi router. Your best solution is to relocate the Wi-Fi router closer to your Roku, or to get a signal booster to extend the range of your Wi-Fi signal.
On a more technical note, your Wi-Fi router may be broadcasting on a channel that has lots of conflict with other Wi-Fi signals in your neighborhood. Changing the broadcast channel requires that you have an administrator login to your router and can make changes. You might have to call your service provider and have them make the changes for you (if you smile right over the phone, they may give you your router's login information, but don't count on it). Best channels to select are generally 1, 6 or 11 to avoid overlap with other channels.
If you have a smart phone and can download an app, look for a Wi-Fi Analyzer app (free). This will show you the other signals around you, what channel they are broadcasting on, and the strength of the signal.
Sep 06, 2017 | Computers & Internet
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
I cannot connect to the internet using my dlink dir-600 router
  • Check the cable modem status light. If this cable is loose at either connection point, you must tighten it before hoping to attain your Wi-Fi signal again.
  • Verify that the Internet light on your Netgear wireless router is solid or blinking green.
  • Press the "Reset" button that is located on the front face, top or rear of the broadband modem. This button allows your modem to re-initialize, and this may solve your problem once it boots back up.
Find here-setting up d-link router
Aug 30, 2012 | D-Link Computers & Internet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
3 computers, connected through a wireless router (Dlink DIR-320), one of them directly through cable, 2 others through Wi-Fi. The task is to connect printer to the local network, so people, who use Wi-Fi...
hello
here it is considering that all computer conneced to internet, and be sure that the three computer is in the same WORKGROUP, if not the these three computers will not able tomake sharing.
to know if these three computer is in the same workgroup right click you computer desktop icon, click on properties and you will see computer name and workgroup name.
need some tips just leave comments
thank you
Mar 08, 2011 | D-Link Computers & Internet
I have a d-link router for my laptop and my wireless has worked fine until abotu a month ago my wireless just stopped working, it says that i have full strength connection like all the bars are showing...
this is a DSL router I think
Try pulling the power to the DSL Dlink wi fi router.
For 30 seconds then plug in back in and switch it on again.
If you have a DSL modem attached to the Dlink wi fi device then down power the DSL modem and wait 30 seconds and repower it up. Wait 5 minutes for it to resync with the dsl on the phone line.
As a side note
Have you had the DSL upgraded like from dsl -1 to DSL -2 if yes then check the dsl filter on the phone line sockets can handle DSL - 2
Diagnostics
go to the P.C windows o/s I hope .
Go to command prompt
ping the routers ip address
10.0.0.1 or 192.168.0.1 is the most likely ip address
type in ipconfig
press enter
what is the default gateway (this is the router ip address)
Type in tracert www.google.com
press enter
Can you resolve the DNS name . and get an ip address
if no then DNS server issue check DNS server settings are they on AUTO . in modem or DSL router .
See if the IP hops get to the modem or to the ISP .
May 13, 2017 | D-Link (DI-784) Wireless Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
There is an excllent signal but i can't access internet
Call your neighbors who own the WI-FI and tell them to pay their internet bill or stop filtering you.
GL!
Aug 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Unable to connect to wireless router . its has a built in wi-fi
go to the start menu..
right click on my computer..
go to properties...
look for device manager..
then look for network adapters..
then they might be something with a yellow exclamation point
press it then install...finished
hope i helped you..
take care..
Apr 20, 2009 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
